Thread: Passat 20v hesitating
  1. Passat 20v hesitating
    Oct 2006
    Sunny slightly hilly Norfolk
    I've got a 1999 1.8 20v APT engined Passat and when decelerating it jumps at 1500rpm as though the throttle is suddenly closing. I'm now getting a hesitation, almost like a misfire, especially when cold on a light throttle. Is the throttle body at fault or what else should I check?The car has done only 79k and fuel economy is acceptable (I think), averaging about 30mpg. Any ideas gratefully received.
    2016 VW Tiguan Match Edition (Nimbus Grey) , 09 Ibiza 1.4 SE SC (Nayara Blue), 2014 Leon 1.2 SE (Candy White).
  2. Re: Passat 20v hesitating
    Bradford
    do you have any flat spots when driving? In the sense that you put your foot down and nothing much happens for a sec and then it goes? i had this issue on my sat, same model same engine code, i cleaned out the throttle body control, using some throttle body cleaner, available from any decent motor shop, been good as gold since.
    my tbc was CAKED in black gunk!
  3. Re: Passat 20v hesitating
    Nov 2008
    Funnily enough I just got my car repaired today and it had a similar problem. On inspection after some juddery weeks I checked under the plastic cover above the drivers side mid engine and found that (here's the technical bit) the charcoal filter thingy, had broken off and required to be repaired/replaced. It seems fine now it's been fixed.
    May be unrelated but worth checking.
  1. Audi A3 2.0 TDI Hesitating when starting
    By dunnie in forum Audi A3 - Archive Topics
    Last Post: 19-10-2008, 11:32 PM
  2. engine hesitating on acceleration
    By hongkongstuey in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-06-2008, 04:18 PM
  3. Hesitating 1.8t
    By 12bamf in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-02-2008, 08:20 PM
  4. Mk3 GTi hesitating
    By my1stGTi in forum Golf MK3 - 1993 - 1999
    Last Post: 30-06-2007, 09:39 AM
  5. Hesitating/holding Back
    By BLACKOPS in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 22-03-2007, 11:25 PM
