Thread: Headlight Switch
  1. Headlight Switch
    Hello All
    New here so looking for some advice.
    I have a 2007 A4 Avant S Line and when I unlocked the car the other evening I saw that a small red led light was flashing on the actual headlight switch (the part that turns). It went out once I turned on the lights and started the engine. The car just has standard lamps and not automatic.
    I have checked the manual and even rang my local Audi centre and no one seems to know.
    Has anyone else noticed this ?
    Sid
  2. Re: Headlight Switch
    Norwich
    Yes mine does this too- and it happened in my previous B7. There is nothing I can see going wrong with the headlights so maybe it is some automatic start up check the lights do.
  3. Re: Headlight Switch
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Yeah,it does light-up as you open the car,same as the hazard switch illuminates,just so you can see them in the dark!!
  4. Question Re: Headlight Switch
    Dec 2008
    Hi there, I am a new a4 owner and i have noticed exactly the same thing with my h/l switch-generally it comes on first startup of the day, then starts to flash sometimes fast, sometimes more slowly, there seems to be a positively spaced flash rather than an erratic bad connection flicker.It defies all logic, and seems to serve no purpose .Annoyingly, at night when it needs to be permanently lit, it is invariably completely off I can only assume then that it is a fault of some sort,the manual makes no mention of it,any ideas, pass `em on!-cheers Bob `C`
  5. Re: Headlight Switch
    Hello, Did any body get to the botton of this light flicker thing, I noticed mine doing it last night. It seems to be like a bad conection sort of flicker as it does what it likes, all other lights come on and go out as they should do.
  6. Re: Headlight Switch
    Dec 2008
    Thats just the same as mine, at first i thought it was flashing at a regular rate, but now i am of the opinion that it IS a bad connection/dodgy diode-it seems to have a mind all of its own, comes on/goes off as it pleases!
  1. headlight switch issue
    By churp in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-08-2008, 08:10 PM
  2. Headlight Switch Illumination
    By c0l in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-02-2008, 04:41 PM
  3. Replacing Headlight Dip Switch Stalk
    By funbox in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-11-2007, 01:22 PM
  4. Headlight switch bulbs gone
    By madfella65 in forum Audi A4 - Archive Topics
    Last Post: 23-01-2007, 08:35 PM
  5. VW Passat Headlight Converter switch
    By ianadie in forum Passat - Archive Topics
    Last Post: 12-07-2006, 09:24 PM
