Thread: T4 2.5Tdi timing marks
  1. T4 2.5Tdi timing marks
    Aug 2008
    Hi, I have replaced the cam belt and pump belt on my 2002 2.5Tdi transporter and i don't think the pump timing is quite right now because it is difficult to start when cold. I found it very difficult to find any timing marks on the fly wheel to confirm i'm on TDC. Could anyone give me any ideas about what the marks should look like? The only ones I can see are two notches close together that don't seem to be on TDC.
    Thanks Mat
  2. Re: T4 2.5Tdi timing marks
    hi the marks on the fuel pump are only a ruff guidence mark so you know that the pump is not 180 degrees out you have to put a dti guage into the end on the pump and set it up that way.
  3. Re: T4 2.5Tdi timing marks
    Aug 2008
    Thanks for that.
    I have got the correct tool now for the pump setup using a dti gauge. The problem I have is there doesn't seem to be any clear tdc marks on either the flywheel or the crank pulley to give me a good starting point.
  4. Re: T4 2.5Tdi timing marks
    when the timing mark is lined up on the crank with the mark on the bell housing and you have locked the camshaft with the tool it will be tdc on cylinder 1
  5. Re: T4 2.5Tdi timing marks
    Sep 2008
    Cornwall
    I remember from my T4 that the TDC mark is quite hard to spot. I think it was a pointer on the bell housing and what looks like a saw cut on the flywheel. You need to get a decent light on it and you can only see it from an odd angle because of all of the stuff that's in the way. Also you really do need to get eveything spot on for it to run right on that engine, so you need to use the cam locking bar and the dial gauge, and you must release the cam sprocket before you tension the front belt.
    I have got the map somewhere I could send you for the ACV engine (the one that you use with a diagnostic tool for getting the pump timing absolutely spot on) but I'm away for the next few weeks so I won't be able to get it for a while.
    Ignore the crankshaft pulley marks they are wrong. (But just close enough to confuse you!) The flywheel marks will be there but they are really easy to miss.
  1. polo sdi timing marks
    By dungatron in forum Polo - Derby - Lupo - Fox
    Last Post: 07-10-2008, 10:16 PM
  2. Crankshaft Timing Marks
    By 106661 in forum Golf MK3 - 1993 - 1999
    Last Post: 09-08-2008, 10:28 AM
  3. Timing marks on sprockets
    By wacker in forum Golf MK2 - 1984 - 1992
    Last Post: 08-05-2008, 01:08 PM
  4. Audi a4 tdi 1997 timing marks
    By shuvit2 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-04-2008, 10:55 PM
  5. Mk2 camshaft timing belt marks
    By dannyholmes in forum Golf MK2 - 1984 - 1992
    Last Post: 25-08-2007, 11:31 PM
