Thread: Heater matrix - no hot air!!!
Results 1 to 10 of 12
  1. #1
    Dec 2006
    Cheers for this guys.... however... in regards to the climate control.... how do i view this in Vag-COM... i have looked and cant see the option??
    also... where to find the info regarding the flaps?
    cheers
    RickT
    7 Post(s)
    If you log into 08 Auto HVAC then selct the measuring blocks, scroll through the channel numbers using the up and down arrows until you find the flap angles.
    Depending upon what version you are running vagcom will either state what the measuring block is or not !
    What you are looking for are the measuring blocks that have a range between 0 and 255. To find the block that relates to the temp flap it will be a process of elimination.
    Dec 2006
    Thanks for that... i will have a look in the morning..
    RicKT
    Dec 2006
    cheers for that... im going to head out in a min to do this....
    However i noticed after a further look the collent seems to have dropped....
    Does the coolent run through the matrix on these??
    The car has been stood for a week in snow etc... however i topped the coolent up and heat seems to be coming back through........
    Im going to out and have a proper look now in the light!
    Cheers.. any other thoughts keep them coming!!
    RicKT
    Dec 2006
    looks like it is the themostat at fault..
    Just got to audi before they closed and got one...
    Will fit shortly and let you know the outcome!
    RicKT
  6. Exclamation
    Dec 2006
    themostat replaced......
    was in a real hard place to get to...
    Alternater had to be removed plus other hoses etc...
    all nows well
    Cheers..
    RicKT
    Feb 2007
    South Yorkshire
    If it's like the VW Climatronic if you press fan 'down', heat down (blue) and econ together you'll get a display of the settings. Scroll using hot/cold buttons.
    Mine has just had a fan motor control ECU failure which has cost a fortune to put right. Symptoms just like yours, feeble heat on Hi, no heat anywhere else.
    First indicater (1) showed cabin temp at 97degreesC.
    Gogsy
  1. Avant heater matrix
    By Scotty Dave in forum 80 - 90
    Last Post: 27-10-2007, 08:00 PM
  2. Audi 80 tdi..heater matrix
    By domross in forum 80 - 90
    Last Post: 21-03-2007, 11:17 PM
  3. Heater Matrix leaked, Radweld recommended or not??
    By TDI in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 11-03-2007, 03:15 PM
  4. Heater matrix reinstall difficulties
    By narge in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 18-11-2006, 11:13 PM
  5. any one changed a haeter matrix?
    By chrispey in forum 80 - 90
    Last Post: 07-10-2006, 06:14 PM
