Thread: Spark Plugs
Results 1 to 10 of 14
  1. Spark Plugs
    Northumberland
    Been servicing the car today (well yesterday), put the new 'recommended' plugs in and then went to drive home and just kept misfiring... anyone any idea what plugs I need for an 03 1.8T A4??
    Going to put the old plugs back in to check thats def what the problem is then pop into the audi dealer, but if anyone knows.....
    Cheers,
    Chris
  2. Re: Spark Plugs
    Chester-le-Street, United Kingdom
    Quote Originally Posted by ChrisBee View Post
    Cheers,
    Chris
    did you gap the plugs,or just assume that the gap would be correct as they came?
    sure you haven't pulled a lead off somewhere?
    first time i was up a ladder i was down a well
    4th cog,--two to go
  3. Re: Spark Plugs
    Northumberland
    Assumed the plugs would be correct as they came - looked exactly the same, so wasn't expecting any problems.
    Cleaned the old plugs this morning and put them back in and everything is right with the world again... and also (in proper daylight) got the model number of the old plugs (PFR60) so off to get some more.
    As the car was 'deed' last night I was expecting the baby to decide that was the ebst time to come, thankfully he's a good lad and stayed put.
    The football looked unlucky for your lot Stewy... Bramble scoring???
  4. Re: Spark Plugs
    chris, you are being kind there,thanks,but they were booed off at half time.
    you can't win a match by only playing one half.
    how they can sleep at night after picking up such stupid wages,for doing nowt,absolutely nowt,is beyond me.
    they got what they deserved, no arguement about that.
    they deserve to be where they are,and how 50k can turn up every time to watch them,well, yes they are very lucky there.
    just got to feel for the die hards,forking out all that money for season tickets, on the strength of nothing more than promises.
    they truly are the salt of the earth.
    are you sure you can't just adjust the gap on the new plugs you put in?
    it could make a world of difference.
    take care,
    stewy.
    4th cog,--two to go
  5. Re: Spark Plugs
    Northumberland
    Didn't know they'd been booed off - just saw MOTD and it looked ok, but thats sometimes the editing!!
    3 sets of spark plugs today, some adjusted some not and still none seem to be working. The Bosch misfire all the time, the Champion when you put your foot down. Put the old ones back in after cleaning them up a bit and a bit of a misfire around 1500 rpm sometimes. Off to try another set of NGK's tomorrow.
    Cheers,
    Chris
  6. Re: Spark Plugs
    Cheers,
    Chris
    chris,
    i'm not trying to tell you how to suck eggs,but if you are putting plugs in without adjusting to the recommended gap,then you arn't actually putting plugs in really.
    you may be better off just keeping the old ones,but clean and then gap them.they must be gapped.
    failing that,if you are sure the plugs are right,then coil packs spring to mind.
    lots of pennies!!!
    take care,
    stewy.
    4th cog,--two to go
  7. Re: Spark Plugs
    Jul 2007
    Cheshire, or my A6
    Assuming the plugs are fitted correctly... all I can say is get genuine ones. Gapped and fitted correctly of course.
    I would never trust a Bosch pattern part in my car, you only have to look at the problems the pattern Bosch MAFs have compared to the genuine ones.
    Paul
  8. Re: Spark Plugs
    Northumberland
    Got some genuine plugs today - going to try them and see how things go. All playing with the car put on hold for today though, baby due tomorrow and looks like he's going to be very unlike me and be VERY punctual.
  9. Re: Spark Plugs
    Jul 2007
    Cheshire, or my A6
    Best of luck bud!
    Paul
  10. Re: Spark Plugs
    Quote Originally Posted by paul b View Post
    Best of luck bud!
    Paul
    you'll need it
    4th cog,--two to go
  1. Question Spark plugs on VR6
    By kanten in forum Golf MK3 - 1993 - 1999
    Last Post: 28-09-2008, 03:12 PM
  2. Spark plugs
    By Imran in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-02-2008, 12:17 AM
  3. Spark plugs
    By xerian in forum Beetle 2000-
    Last Post: 27-01-2008, 06:09 PM
  4. V6 3lt spark plugs
    By Dozz in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-06-2007, 10:48 PM
  5. Spark Plugs
    By rickgti in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 02-05-2007, 05:07 PM
