Having finally decided to buy the Ross-tech cable and VCDS from ilexa.co.uk I put my car through the Auto-Scan. 9 error codes!!! This is after having reset all DTC's about 3 weeks ago.
2 months ago there were a few components replaced such as the MAF and most vacume hoses.
If anyone can offer any tips or advice on the below it would be most appreciated - especially with the engine faults. I've had a look at the ross-tech wiki but would be interested if any of these faults are realted or if I should start by fixing a partucular one with the hope that another would be fixed as a result...
Saturday,15,November,2008,12:50:14:39342
VCDS Version: Release 805.1
Data version: 20081017
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8E_________ Mileage: 188660km/117227miles
Address 01: Engine Labels: None
Part No SW: 8E0 907 557 F HW:
Component: 2.0L R4/5VS 0006
Coding: 0011581
Shop #: WSC 63351 000 00000
2 Faults Found:
17887 - Brake Boost Vacuum System: Mechanical Failure
P1479 - 008 - Implausible Signal
17545 - Fuel Trim: Bank 1 (Add): System too Rich
P1137 - 002 - Lower Limit Exceeded - MIL ON
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No: 01J 927 156 AE
Component: V30 01J 2.0l 5V RdW 1756
Coding: 00001
Shop #: WSC 00579
No fault code found.
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front D620
Coding: 04279
Shop #: WSC 00579
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043
Component: A4 Klimaautomat 0406
Coding: 00000
Shop #: WSC 63351
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00001
Shop #: WSC 00579
1 Fault Found:
00532 - Supply Voltage B+
53-10 - Supply Voltage Too Low - Intermittent
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655
Component: Airbag 8.4E 3001
Coding: 0010602
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 L
Component: Lenksáulenmodul 0308
Coding: 00011
Shop #: WSC 00579
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 D
Component: KOMBI+WEGFAHRS. RB4 D10
Coding: 00400
Shop #: WSC 00579
WAUZZZ8EZ_______ AUZ6Z0Y_______
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0403
Coding: 00001
Shop #: WSC 00000
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 AJ
Component: Komfortgerát T9F 0619
Coding: 06894
Shop #: WSC 00579
Part No: 8E2959802B
Component: Tőrsteuer.FS BRM 4.11
Part No: 8E2959801B
Component: Tőrsteuer.BF BRM 4.11
4 Faults Found:
01616 - Signal Wire to Interior Monitor
49-10 - No Communications - Intermittent
01331 - Door Control Module; Driver Side (J386)
80-00 - Single-Wire Operation
00913 - Window Regulator Switch; Front Right Driver (E81)
27-10 - Implausible Signal - Intermittent
00932 - Electric Window Motor; Drivers Side (V147)
62-10 - No or Incorrect Adjustment - Intermittent
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 186
Component: concert II GRO 0001
Coding: 00001
Shop #: WSC 63351
2 Faults Found:
00856 - Radio Antenna
36-10 - Open Circuit - Intermittent
00858 - Connection; Radio ZF Output to Antenna Amplifier
36-00 - Open Circuit
Thanks,
uk-Pedro
