Thread: A6 Avant - bootlid seal leaking
  1. A6 Avant - bootlid seal leaking
    I have a 2001 A6 Avant 1.8T. The seal around the tailgate has come loose on the drivers side and is letting water seep into the interior. This means that the carpet lining on the inside of the tailgate is constantly wet, and I have to put up with near constantly steamed-up windows in wet weather.
    I have tried to put it back into shape, but it must have been loose for quite a while before I noticed it and with the tailgate constantly banging shut on it, it is now beyond repair. It is not a normal rubber seal, it seems to be made of a combination of reinforced rubber with a type of material over it.
    Does anyone know how/where to get hold of a replacement? I do wnat to eventually upgrade the car to the current model, but need to keep it going for about another year.
  2. Re: A6 Avant - bootlid seal leaking
    Mar 2008
    High Wycombe
    It's not the sort of thing that you'll get as a pattern part. I think your only options for a replacement are a breaker or a main dealer.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  1. A4 avant rear wash wipe leaking inside
    By apjm57 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-02-2010, 09:12 PM
  2. A4 Avant '97 2.8 Quattro Leaking Steering fluid
    By cheeseplant in forum New Member Introductions
    Last Post: 10-03-2008, 11:50 PM
  3. A4 Avant '97 2.8 Quattro Leaking Steering fluid
    By cheeseplant in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-03-2008, 11:40 PM
  4. 99 Avant Bootlid handl. Same as saloon?
    By AdamC in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-12-2007, 11:14 AM
  5. Coupe leaking rear light seal
    By cleggn in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 15-07-2007, 08:18 AM
