Thread: Engine noise only when heater fan on
  1. Engine noise only when heater fan on
    Hi all, my 130BHP TDI passat est circa 2004 intermittently emits a cross between a bearing grinding noise and a clunk about every 5 seconds.
    It sounds like its coming from either the centre or nearside at the front of the engine, probably one of the ancillaries running off one of the belts.
    Weird thing is that it stops when the heater fan is turned off.
    Any ideas would be greatly appreciated.
    thanks in advance
  2. Re: Engine noise only when heater fan on
    Quote Originally Posted by stu View Post
    thanks in advance
    Check the ancillary belt tensioner, the top bush wears and the pulley runs on the top of the tensioner cutting grooves in it. Not so weird with the heater, the belt drives the alternator, the alternator drives the fan, no fan low load, fan on, high load!
  3. Re: Engine noise only when heater fan on
    Thanks Caldirun. makes total sense. I will check it out.
  4. Re: Engine noise only when heater fan on
    131 Post(s)
    1973 Post(s)
    Turn the heating system onto ECON from AUTO and if the noise stops, you have a problem with the A/C compressor or its drive.
  5. Re: Engine noise only when heater fan on
    Thanks for the reply. It doesn't make any difference wether its on econ or auto. Only affected when fan on or off.
    UPDATE -
    Turns out it was the clutch mechanism on the alternator. OUCH £168+ vat for new one (alternator).
    Also replaced tensioner as this looked like it was on its way out.
    Thanks for the replies.
  1. noise from engine.
    By amphiltis in forum Golf MK3 - 1993 - 1999
    Last Post: 05-09-2013, 07:46 PM
  2. TDI 170 Engine Noise
    By Alistair101 in forum Golf MK5 - 2004 - 2009
    Last Post: 21-04-2008, 06:22 PM
  3. 1z engine noise
    By eddiemax28 in forum 80 - 90
    Last Post: 27-01-2008, 02:14 PM
  4. Noise from engine - help
    By mmm777 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 15-09-2007, 03:56 PM
  5. Heater Fan noise
    By Turkster in forum Passat - Archive Topics
    Last Post: 08-02-2007, 06:02 PM
