Thread: Vagcom/VCDS User Locations
Page 34 of 35 FirstFirst ... 2432333435 LastLast
Results 331 to 340 of 344
  1. Re: Vagcom/VCDS User Locations
    Nov 2021
    Manchester
    Hi, Anyone with Odis tool is available in or around Manchester area, I have messed up Audi Q7 4m air suspension, need help to reset the module? TIA
  2. Re: Vagcom User Locations
    Feb 2012
    folkestone.uk
    Do you still do code reading.
  3. Re: Vagcom User Locations
    Aug 2015
    Cambridgeshire
    I have the latest HEX-V2 in Peterborough (PE6)
  4. Re: Vagcom/VCDS User Locations
    Jul 2022
    Southampton
    Hi anyone in the southampton area that can code my MFSW to a t5.1?
    Thanks Matt
  5. Re: Vagcom/VCDS User Locations
    Aug 2008
    Flitwick, Beds
    Anyone with Vagcom in mid beds area, south of Bedford? Need a throttle body programmed to the car. Skoda Fabia 1.4 16v.
  6. Re: Vagcom User Locations
    Jun 2023
    Swindon
    Hello mate. I’m from swindon and I need your help if possible, I need to allow my radio (Symphony 2) from an Audi tt mk2 for the Aux cable that I plugged on the back of the radio.
    Need someone with the vagcom to help me with that if possible.
  7. Re: Vagcom/VCDS User Locations
    Nov 2023
    Scarbados
    Anyone in the Scarborough UK area?
    Got a sticky problem that needs unsticking!
    08 A3 CR170 that's had its immobiliser bypassed, we are assuming because it's knackered.
    I've a used Clockset with accompanying ecu, locks, ignition, key etc but have zero clue!!
    Very scant info from the greasy seller so we've got what we've got to work with.
    Any help would be ace.
    Sincerely
    Patrick.
  8. Re: Vagcom/VCDS User Locations
    1841 Post(s)
    To do that properly you need someone with ODIS and GEKO security clearance.
  9. Re: Vagcom User Locations
    Dec 2023
    Rowley regis
    Hi there where are you based please
  10. Re: Vagcom/VCDS User Locations
    Dec 2023
    Rowley regis
    Any one near Oldbury west midlands ??
  1. New VCDS ODB2 user- Lancashire
    By f2raf in forum VCDS - Help Requests
    Last Post: 08-09-2011, 10:47 AM
  2. nearest vagcom user (birmingham)
    By vwcamperman in forum VCDS - Help Requests
    Last Post: 23-11-2009, 01:05 AM
  3. Looking for VAGcom user in Northampton
    By 1.8tgav in forum VCDS - Help Requests
    Last Post: 17-11-2009, 04:42 PM
  4. Re: Vagcom User Locations
    By skippy41 in forum VCDS - Help Requests
    Last Post: 20-11-2008, 07:25 PM
  5. VagCom port locations
    By morticiaskeeper in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 29-07-2007, 02:10 PM
