Thread: Vagcom/VCDS User Locations
Page 11 of 35 FirstFirst ... 91011121321 ... LastLast
Results 101 to 110 of 344
  1. Re: New Vag-com.
    2daysway Guest
    Quote Originally Posted by kje View Post
    Just bought USB/CAN version and snazzy new laptop to operate.
    Fixed airbag faults, re-progged key/door locking/drive away function & 'beep'.
    Well chuffed and I don't 'do' computers!
    Happy to help (*try*) if you're local (only if you fix my winter condensation ).
    Gatwick/Horley.
    I have an Audi a6 TDI SE 2.5 2002, an am thinking of buying vag-com to help me diagnosis some existing faults, I would really like to demo this system to learn nore about real application. Can you help?
  2. Re: Vagcom User Locations
    Alloa Scotlad
    Hi Scotsman.
    Have Passat SE20 Engine, Problem severe hunting, have to run with vacuum hose
    disconnected. Believe problem could be with electronic idle control,
    [needs throttle adaptation].
    Can you assist.
    Sig
    Alloa
  3. Re: Vagcom User Locations
    Oxford, uk
    Interface: HEX-CAN/USB Cable & VAGCOM v912
    Experience: Just learning how to use it but I'm willing to help any forum members in my locality.
  4. Re: Vagcom User Locations
    Sep 2008
    Kent
    Interface: Ross-tech genuine cable, Hex-Can full version (cost me £263!)
    Ability: Trained Mechanic (although I don't work in the trade anymore)
    Version: 908
    Cars Covered: 1996-2009 16pin with or without can-bus
    Can also rewind the rear calipers on electronic handbrake equipped cars for pad replacement.
    Will help anyone and travel for beer tokens.
  5. Re: Vagcom User Locations
    Peterborough
    anyone in the leicester or peterborough area?
    got a mk6 (Se) 1.4tsi and would like to activate a few stuff.
    im new to this all...
  6. Re: Vagcom User Locations
    Jul 2008
    South Lincs
    Quote Originally Posted by illestjt View Post
    I'm near to grantham if it's any help
    Daily Driver - 2004 Gloss Black MkIV GTTDI
    Resto Project - 1988 Diamond White Escort RS Turbo
    Fully Registered & Upto Date CAN-HEX USB VCDS (VAG-COM) & VAG-TACHO
  7. Re: Vagcom User Locations
    Jan 2010
    Hove
    HI ALL: I moved to Australia in 2011 - so probably not much use to the people of Sussex anymore...
    Hex +CAN (USB) - latest lead and software version, which can do everything...
    Don't have too much experience - have used it to view and clear DTCs, view and graph measurements and done a a few basic operations. Car still isn't running 100% so I presume I'll learn a lot in the next while.
    Seamus
  8. Re: Vagcom User Locations
    Feb 2010
    Halifax, West Yorks
    Location: Queensbury (between Halifax and Bradford, West Yorks)
    Experience: Just learning how to use it but I'm willing to help any forum members nearby.
  9. Re: Vagcom User Locations
    Nov 2008
    Leeming
    Interface: Ross-Tech Hex-usb+can
    Experience: Know my way around the measuring blocks, coding and adaptations, been diagnosing for a year
    Not really into teaching people how to use VCDS, just helping them
  10. Smile Re: Vagcom User Locations
    Jun 2009
    swindon
    Quote Originally Posted by Frenchman View Post
    Im in Swindon and have Vag-com and cable.
    Frenchman
    Hi frenchman, ive got a vw passat tdi 130 est and need it checking with a vag-com.i bought a vag 405 just to do basic checks which helped me clear my airbag fault.its heavy on diesel and need to know if its the coolant sensor or somethink else . i to live in swindon and willing to pay for your help .its due for mot soon and would like to get this matter fixed incase it affects mot test .and would like to see vag-com in action and how its used .many thanks phil.
  1. New VCDS ODB2 user- Lancashire
    By f2raf in forum VCDS - Help Requests
    Last Post: 08-09-2011, 10:47 AM
  2. nearest vagcom user (birmingham)
    By vwcamperman in forum VCDS - Help Requests
    Last Post: 23-11-2009, 01:05 AM
  3. Looking for VAGcom user in Northampton
    By 1.8tgav in forum VCDS - Help Requests
    Last Post: 17-11-2009, 04:42 PM
    By skippy41 in forum VCDS - Help Requests
    Last Post: 20-11-2008, 07:25 PM
  5. VagCom port locations
    By morticiaskeeper in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 29-07-2007, 02:10 PM
