Thread: A6 TDI 130 PD Intermittent power loss
Results 1 to 9 of 9
Hybrid View
  1. A6 TDI 130 PD Intermittent power loss
    Feb 2007
    Hello, as the title suggests I have an A6 52 reg 1.9 TDI 130. Occasionally as I am accelerating the car will not respond, If I let off the accelerator and then press it again the car will respond normally,and at other times this does no good. This problem seems to be steadily getting worse. The car is great apart from this and has a full service history. I know it could be the MAF sensor or the N75 valve, Does anyone know how to test these ? Cheers for any help you can give, John.
    Last edited by really wants an RS6; 14-02-2007 at 07:52 PM. Reason: wrong spelling
    7 Post(s)
    If you have vagcom you can test the MAF by logging the airflow, however I'd say it's unlikely to be the MAF.
    The N75 can also be tested from vagcom via the output tests once your logged into the engine control module, you will simply hear the N75 solenoid clicking.
    I'd also check out the throttle position sensor as well (throttle pedal with attached sensor).
    Do you have cruise ?
    If so, you could eliminate both the MAF and the N75 by accelerating with the cruise.
    Also the VNT turbos or the vanes in them can get sticky if the engine isn't rigorously excercised on a fairly frequent basis. This will also give diminished performace and smoke out the back...
    Does it smoke when you hoof it btw ? ... could point to the sticky turbo fault.
    Best advise is to get it scanned and checked by someone with vagcom. I've got vagcom and am in Maidenhead Berks and could help but no doubt your in Aberdeen or somewhere equally distant.
  3. small world
    Feb 2007
    Suprisingly I am in High Wycombe and thanks for the prompt reply. I do not have cruise, but why would that prove it wasn't the MAF sensor ? No smoke, no strange noises just a lack of power, and I mean a big lack of power.
    PS. I am not doubting your knowledge, I am just curious as to why cruise would allow the car to accelerate with a knackered MAF sensor.
    7 Post(s)
    Quote Originally Posted by really wants an RS6 View Post
    Having re-read my post it that bit makes no sense !
    What I meant was...
    Accerating with cruise would confirm throttle sensor on the pedal as being the culprit or otherwise.... why I typed and referenced MAF, god knows.
    Feb 2007
    Cheers mate, now I understand. Why do you say it's unlikely to be the MAF meter (not sensor, I don't know why I put sensor) I thought VW and Audi had a problem with those or was this sorted before 02, or was I misinformed.
    7 Post(s)
    Yes, the MAF are notorious for failing however it usually happens very gradually.
    Aug 2006
    HAVE YOU TRIED THE SIMPLE THINGS FIRST LIKE CHANGING THE FUEL FILTER SALTY
    Feb 2007
    Quote Originally Posted by salty View Post
    No mate I assumed that as it had a service a month ago and it is on long life servicing that the fuel filter would have been changed but I will check cheers.
  1. A4 1.9TDI Intermittent power fault
    By Dave.jj in forum Audi A4 - Archive Topics
    Last Post: 13-02-2008, 04:19 PM
  2. Audi 80SE Intermittent loss of accelaration
    By rossclan in forum 80 - 90
    Last Post: 21-04-2007, 10:26 PM
  3. Intermittent lack of power & smoking exhaust
    By t.ellison@tesco in forum 80 - 90
    Last Post: 08-04-2007, 09:40 AM
  4. A4 TDI 130 intermittent power loss
    By chris.b in forum Audi A4 - Archive Topics
    Last Post: 30-11-2006, 10:15 PM
  5. A4 2.5tdi intermittent, then solid, power loss
    By rob7706 in forum Archive posts
    Last Post: 05-10-2006, 08:00 PM
