Thread: Audi A4 2005 Air Conditioning
  1. Arrow Audi A4 2005 Air Conditioning
    Nov 2008
    Hi Folks,
    First time on this forum, hope I'm posting on the right section.
    There is a strange smell coming from the Air conditioning/e con system when i turn it on. (Smells a bit like smelly socks) Any idea what is causing this and how I can fix it?
    All advice is appreciated.
  2. Re: Audi A4 2005 Air Conditioning
    Mar 2008
    High Wycombe
    Usually a smelly air con system is caused by bacteria / algae growing on the evaporator (which is the bit that gets cold in the back of the dashboard).
    I have seen that a method of curing this is to buy a spray can of dettol disinfectant, remove the pollen filter, turn the aircon on and spray half a can of the dettol liberally into the aircon intake. This should kill the bacteria and leave your aircon with a pine fresh fragrance.
    I've not used this method - I've never had mine smelling bad yet, but once a year, a bloke comes around our office and sprays stuff onto the evaporators of all our office air conditioners to kill off the bacteria.
    Hope this helps
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  3. Re: Audi A4 2005 Air Conditioning
    Nov 2008
    Cheers thanks for the advice, any idea how to remove the pollen filter?
    Can I do this myself?
  4. Re: Audi A4 2005 Air Conditioning
    Cheshire, or my A6
    If it is like my 2003 A6...
    To the right hand side of the battery, underneath the black scuttle panel. Really easy to change. The new filter will probably be less than £10 from Audi.
    Paul
  5. Re: Audi A4 2005 Air Conditioning
    Aug 2008
    Hereford
    Also spray sum dettol stuff down each of the blower vents, the proper stuff comes with a long flexi pipe similar to the wd40 pipe which allows u to insert down the window blower vents too, squirt it whilst pulling the tin back slowly to ensure all bacteria is sprayed also spray ur pollen filter too wi a little bit,
  1. Audi A6 2005 MMI Directory Problem
    By Kaushal in forum In Car Entertainment
    Last Post: 31-07-2011, 06:03 AM
  2. Please Help Air Conditioning/fan problems AUDI A3 1.8SE 20V (2000 model)
    By madgoose in forum Audi A3 - Archive Topics
    Last Post: 04-11-2008, 08:57 PM
  3. Audi A3 2.0 TDI 2005
    By CriticalBeat in forum Audi A3 - Archive Topics
    Last Post: 16-07-2008, 10:16 AM
  4. Problems with Audi A8 2005 3L Petrol
    By adnan348 in forum A8 - S8 - V8
    Last Post: 19-03-2008, 06:46 AM
  5. audi a8 2005 check navigation dvd msg on MMI
    By billboos in forum A8 - S8 - V8
    Last Post: 24-02-2008, 04:30 PM
