after heavy rain the rear drivers side footwell is sodden, i don't have a sunroof, and after reading comments about the pollen filter, I had a look below the windscreen and there does appear to be small pools of water!!! however these are not near the drain holes, whick appear to be unblocked (the angle of the road means the car isn't level, so the water sits near the middle of the car, and doesn't drain away) how easy is it to remove the plastic cover to gain access to this area properly? as far as I can see I need to remove the windscreen wipers.
