Thread: Boot lid light and number plate light panel
  1. Boot lid light and number plate light panel
    Jul 2007
    Hi !
    Does any body know what is involved in removing the boot lid light and number plate panel ?
    It looks as though it is one unit so should come off in one piece
    Any advice appreciated
    cheers !
    Brett
  2. Re: Boot lid light and number plate light panel
    Dec 2007
    There are 2 8mm bolts behind the boot carpet trim. To get to these you need to pull out 4 or 5 plastic blanking plugs with a small screwdriver and then gently pull the carpet down. I have just done this on my coupe, dont know if it the same for other cars.
  3. Re: Boot lid light and number plate light panel
    Jul 2007
    I am always grateful to any one who takes the trouble to make a reply...so thank you.
    Unfortunately the rear of the cabriolet must be different to the coupe.
    With the Cabbie the number plate and the light unit are part of the boot lid where as in the coupe they are below i.e. not part of the lid
    It looks fairly straight forward - 4 nuts per side for the side lights and then two plastic lugs which push through the panel two hold the number plate and provide additional support in the middle.
    My concern is the lock is screwed to the boot lid and has many different wires and linkages...I am wary to take these off with out checking first
    Rgds
    Brett
  4. Re: Boot lid light and number plate light panel
    Sep 2008
    Hi I had mine off the other day to replace the lock, I found a link to utube which had a video of the whole process. Do not forget to unscrew the screws hidden in the pull down handles, I think its 2 and yes you will need the tourqx screwdriver. hope this helps
  5. Re: Boot lid light and number plate light panel
    Jul 2007
    Dont suppose you can remember the link or what you typed to find it ?
    Thanks for letting me know though
    Brett
  6. Re: Boot lid light and number plate light panel
    Sep 2008
    sorry , I have had a look and I think it might have been on bebo, I have tried utube. I navigated to it via google, good luck. By the way got complete lights and bar from scrap yard cost 3 quid easy instal. rds
  1. Audi A4 Dashboard Instrument Panel Light Bulb Dash Light Fix
    By cbi004 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-07-2011, 08:39 AM
  2. Boot Interior Light and Ashtray Light
    By GTI X Man in forum Golf MK4 - 1999 - 2004
    Last Post: 25-02-2008, 01:08 PM
  3. Rear number plate light replacing
    By MotM in forum Audi A3 - Archive Topics
    Last Post: 08-02-2008, 07:48 PM
  4. Number plate light, replacing
    By irishyop in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-12-2007, 03:16 PM
  5. Number plate light
    By shd01 in forum Touran - Sharan - Caravelle
    Last Post: 21-11-2006, 10:43 AM
