Thread: horrible Rattle at low Revs
  1. horrible Rattle at low Revs
    Hi my 1.6 a3 has developed a loud metallic rattle when i pull off at low revs coming from the engine bay (maybe the passenger side) it also occurs when i change gear and the revs drop and the car starts to judder (all together it feels like the engine is going to drop out). i am starting to look into buckers24 post and a local mechanic said it was a worn down bush on the gear linkage but it sound alot more serious than that.
    any help would be greatly appreciated.
  2. Re: horrible Rattle at low Revs
    Chester-le-Street, United Kingdom
    it may be something simple like a cracked exhaust bracket.the exhaust makes an awfull noise when catching on the bodywork.
    stewy.
    first time i was up a ladder i was down a well
    4th cog,--two to go
  3. Re: horrible Rattle at low Revs
    time to get the trolly jack out but what do you think about the gear linkage idea thanks for the reply
  4. Re: horrible Rattle at low Revs
    Sep 2008
    Birmingham
    Get it up in the air and get somebody to give her a rev whilst you're underneath, there's no point coming to conclusions before you've sourced the fault.
  5. Re: horrible Rattle at low Revs
    it is possible yes,but i would have thought that if it was making such an obvious noise,
    then you would be able to feel it,or even see it, directly through the gear lever.
    stewy.
    4th cog,--two to go
  6. Re: horrible Rattle at low Revs
    Aug 2007
    west midlands, uk
    heatshield on the cat??
    mine had 2x broken bolts & used to rattle like death... lol...
    check that 1st
  7. Re: horrible Rattle at low Revs
    ill give it a once over when i get it in the air also i realised this rattle developed when i had the starter motor replaced could it be linked to that
    thanks
  1. A4 1.9TDI 110hp 1997 sounds horrible
    By richard3009 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-09-2008, 04:04 PM
  2. Horrible cam tensioner
    By Whyteknight_uk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-04-2008, 11:57 PM
  3. windows!central locking! and some Horrible noise!
    By saj in forum Golf MK4 - 1999 - 2004
    Last Post: 26-10-2007, 09:54 AM
  4. Kangaroo-ing at low revs and Revs staying high on Gearchange.
    By Dancake in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-10-2007, 05:50 PM
  5. horrible noise when I start my GTI Turbo
    By Nicks in forum Archive posts
    Last Post: 21-02-2007, 06:32 PM
