Thread: Another alarm problem
Results 1 to 10 of 11
  1. Angry Another alarm problem
    Mar 2008
    Hi all iv got 02 130 BHP passat and been suffering with alarm problems for monthes now my mechinic had a look at it and put it on a diagnost machine and cleared all error codes but a week later it still showing that the bonnet is open we havent been able to lock car outside our house for monthes PLEASE could any one throw some more light on the subject
  2. Re: ANOTHER Bl**DY ALARM PROBLEM
    Water leak, from pollen filter area, i have same car. Check if your car had recall for this. My car had alarm issue back in 2006, dealer fixed was caused by water getiing true pollen filter seals.
  3. Re: ANOTHER Bl**DY ALARM PROBLEM
    Mar 2008
    Ok thanx for reply how do i go about finding this out who do i ring
  4. Re: ANOTHER Bl**DY ALARM PROBLEM
    here mate,
    i checked my old invoice by VW dealer
    CARRIED OUT CHECKS REF ALARM GOING OFF
    FOUND POLLEN FILTER HOUSING LEAKING AND DAMAGE TO WIRING AT BOTTOM OF N/S/F A PILLAR.
    REPLACED PLUG, CONNECTERS AND RESEALED POLLEN FILTER HOUSING.
    About outstanding recalls, you need ring your main dealer and ask them if any outstanding recalls on your car. It should be free of charge service, and does not matter if you have no Service History record.
  5. Re: ANOTHER Bl**DY ALARM PROBLEM
    Mar 2008
    Hi mate i rang South Hereford volkswagen dealer today about problem and she said on the phone that the problem is nt covered by a recall but if we took our car in for a full service it would have been picked up by there mechinics is it much of a job to do
  6. Re: ANOTHER Bl**DY ALARM PROBLEM
    Quote Originally Posted by seren View Post
    They should do at least polen filter seal free of charge + plenuim drains. I can give you part numbers for parts been used, i dont think it wil cost much.
  7. Re: Another alarm problem
    Mar 2008
    Hi mate just spoke to a bloke on a different web site and he said to take batterie out and the tray and clean the drain plugs out but i cant see how that will prevent the alarm going off how do i get rid of the picture on the dash thats saying the bonnet is open
  8. Re: Another alarm problem
    http://www.weirdlittlebiscuit.com/passat/leak/
    Hope this will help mate,
    to get rid of bonet light you need clear fault codes, you can do it easily with buying cable from ebay, and using Vagcom software.
    i would check pollen filter area as well removing pollen filter box.
    Check as well any sign of water inside car, wet carpets etc.
  9. Re: Another alarm problem
    I had a problem like this and took my passat to the daelers as it had some warranty.
    VW said it was the bonnet switch spring. They also said that they found faults with the courtesy lights inside the car but did not elaborate.
    Wish I could be of more help
  10. Re: Another alarm problem
    Sep 2008
    disconnect your bonnet switch if it will help. On the actual metal lock, there is a small micro switch, probably covered in grease so it maybe hard to spot, just means your bonnet will not be alarmed. As far as the pollen filter seal goes, what the dealership do is take the old rubber seal off and replace with what they call " dum dum sealer". a long strip of play-do, which fits round the pollen filter. 10 min job. will cost around 10 pounds. beats paying the dealership
  1. Stuck door problem, central locking problem & no alarm
    By andyaudia4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-11-2008, 05:57 PM
  2. alarm problem
    By freeze101 in forum Scirocco - Corrado
    Last Post: 16-04-2008, 10:17 PM
  3. Alarm problem
    By TheMadhatter in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-12-2007, 08:28 PM
  4. A3 alarm problem
    By Mrs K in forum Audi A3 - Archive Topics
    Last Post: 13-05-2007, 09:58 AM
  5. A4 alarm problem.
    By tomyj81 in forum Archive posts
    Last Post: 30-01-2007, 11:48 AM
