Thread: Charcoal filter Solenoid problem??? AEB engine
  1. Charcoal filter Solenoid problem??? AEB engine
    HI as title really since the battery was disconnected (don`t know if its related) but the charcoal filter solenoid clicks loudly and continually do I need to reset something? If I unplug it the solenoid the car idle`s and runs fine anyone have any ideas the car is a 97 1.8T AEB engine thanks in advance..
  2. Re: Charcoal filter Solenoid problem??? AEB engine
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Hi,the only info i can give is that its ECU controlled and wont operate until when the engine is up to temp.and then it will only open/modulate when the engine is under load so as not to put too rich a mixture of fuel/tank vapour into the intake and damage the Cat.Its situated under the drivers wheel arch liner.Easy to get to after taking a few torx screws out.You shouldn`t need to reset anything after Batt.disconnected.Good luck.
  1. engine mount solenoid valves
    By kangtdi in forum VCDS - General Questions
    Last Post: 09-12-2009, 05:20 AM
  2. engine mount solenoid nalve
    By coupe2 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-09-2008, 07:25 AM
  3. Question Faulty Charcoal Filter/ Hissing Petrol Cap
    By matty_smash in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-08-2008, 09:26 PM
  4. 1998 a6 2.5 td1 N75 solenoid problem
    By mickcurran in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 20-02-2008, 12:28 AM
  5. Passat 1.8T Auto - Activated Charcoal Filter Solenoid
    By radiaa in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-08-2007, 11:39 AM
