Thread: Door handle
  1. Door handle
    Hi guys
    I have just purchased a R reg (Dec97) Passat 1.8 turbo estate which has a few faults.
    I notice the central locking/door locks in general seems to be a problem area and have read on how to strip the door down etc.
    The fault on mine is that the central locking works fine via the switch on the drivers door but not with the key, this isn't a major problem at the moment as I am locking all of the other doors with the switch and the drivers door with the key.
    My question is the drivers door handle sticks out by about 1/2 an inch on the left hand side so at times to get the door to open I have to push the handle in and then pull it out to get the door to open.
    Is there any way I can adjust the handle externally to fix this problem and to put the handle back in its original place with out having to pull the door trim etc off.
    Hope some one can help.
    Cheers Jim
  2. Re: Door handle
    Any one got any suggestions ???
  3. Re: Door handle
    Jul 2008
    Lisburn
    16 Post(s)
    Hi Jim
    I have much the same prob the passenger door will not lock with the button and the drivers sticks out and is getting hard to open and lock and unlock with the key. Where did you read up on how to adjust?
    Stewart
  4. Re: Door handle
    Quote Originally Posted by swalker View Post
    Hi Jim
    Stewart
    Hi Stewart I haven't found anywhere yet that tells me how to adjust.
    Some one gave me this link
    http://www.taligentx.com/passat/main...lockmechanism/
    sections 15-18 mention the cable to the handle & how to remove the lock so I did this you can slightly alter the tension on the cable but this has no effect on adjusting the handle.
    Please let me know if you have any luck in finding anything out.
    Cheers Jim
  1. Interior door handle and door panel removal guide
    By sferg55 in forum Bora - 1998 - 2005
    Last Post: 19-10-2008, 09:59 AM
  2. How To Remove door handle (rear door)
    By KeefP in forum Golf MK4 - 1999 - 2004
    Last Post: 23-05-2008, 08:26 PM
  3. Question drivers door handle
    By drodders in forum Touran - Sharan - Caravelle
    Last Post: 23-05-2008, 03:16 PM
  4. Door Handle conversion
    By Dj_Ghost in forum Golf MK4 - 1999 - 2004
    Last Post: 14-01-2008, 10:11 PM
  5. Door Handle &
    By b4a4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-09-2007, 08:15 PM
