Thread: dash pod bulbs 1994 audi coupe
Results 1 to 8 of 8
  1. dash pod bulbs 1994 audi coupe
    Nov 2008
    how do you remove the dash pod so that you can change any blown bulbs, my clockback light has blown, i would also like to change to blue is this possible?
    thanks
    steve
  2. Re: dash pod bulbs 1994 audi coupe
    Pembrokeshire
    22 Post(s)
    easy job. first remove the upper shroud behind the steering wheel by undoing the two philips screws either side from below. pull it up at the front< towards steering wheel>, then pull towards you. put this to one side, then undo the two screws that this was hiding at the bottom of the instrument panel. the panel will then pull out from the bottom first. there will be wiring connectors you need to pull off. two have a red tag in the middle. pop this up with a screwdriver and wriggle the connector off,then remove the panel. the bulb for the clock is next to the yellow connector. now is also a good time to check for any dry joints and resolder if required<if you temp guage doesnt work>. i havnt tried a blue bulb kit but have seen them on ebay. i did struggle to get standard bulbs though as the bulb and mount are one piece, so dont try to pull the bulbs out. reassemble is reverse of removal.
  3. Re: dash pod bulbs 1994 audi coupe
    Nov 2008
    Thank you very much i will do this once i have found out what bulbs i need and where to get them.
    steve
  4. Exclamation Re: dash pod bulbs 1994 audi coupe
    Steve try this link they sell all types of dash bulb etc
    http://www.autobulbsdirect.co.uk/das...12v-c-588.html
    Cookie
  5. Re: dash pod bulbs 1994 audi coupe
    Pembrokeshire
    22 Post(s)
    my local supplier has a large box with loads of different ones in, and none fitted. I think vag are the best bet as there are 3 different types in there. had a look on that link and not sure?
  6. Re: dash pod bulbs 1994 audi coupe
    Nov 2008
    Looks like i have a job for next weekend then, thank you for your replies.
    Just athought, how do you remove the bulbs from the heater and the three dials below, cant have half red and half blue, that would look tacky !
    steve
  7. Re: dash pod bulbs 1994 audi coupe
    Pembrokeshire
    22 Post(s)
    the 3 control knobs just pull off, they will be tight but they do. behind youll find two screws, undo these and off she comes.
  8. Re: dash pod bulbs 1994 audi coupe
    Nov 2008
    I know what you mean, rather like the old merc system, the dial clips over a hollow tube, good system but easily broken, mm i will have to think on replaceing them i think !
    thanks
    steve
  1. power steering pump audi coupe 1994
    By groag60 in forum 80 - 90
    Last Post: 16-03-2008, 03:35 PM
  2. 16v Audi Coupe 1994
    By ANDY301 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 06-01-2008, 02:03 PM
  3. Water hose clip for 1994 audi 90 coupe
    By lexxb88 in forum 80 - 90
    Last Post: 03-07-2007, 12:10 AM
  4. Water hose clip for 1994 audi 90 coupe
    By lexxb88 in forum Archive posts
    Last Post: 02-07-2007, 07:40 PM
  5. Audi Coupe Dash Removal
    By davebatt69 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 11-11-2006, 12:36 AM
