Thread: Clean your Air Mass Sensor !!!!!
Page 3 of 9 FirstFirst 12345 ... LastLast
Results 21 to 30 of 88
  1. Re: Clean your Air Mass Sensor !!!!!
    #21
    May 2007
    Poole
    Has anyone taken any piccies of cleaning a MAF?
    I think mine might need a bit of a polish(?), how do I take it out? Which bits should I clean? Are there any pitfalls - like can I screw up the engine?
    Julian Whitehead
    2001 A6 Avant 2.7T Q
    Swing Unlimited | www.subb.co.uk | www.myspace.com/swingunlimitedbigband
  2. Re: Clean your Air Mass Sensor !!!!!
    #22
    May 2007
    Poole
    Aha - have found the desired instructions here - what do people think?
    http://forums.vwvortex.com/zerothread?id=1446627
    Julian Whitehead
  3. Re: Clean your Air Mass Sensor !!!!!
    #23
    Aug 2007
    Newport, Wales
    7 Post(s)
    Quote Originally Posted by webchem View Post
    That guide is ok, but you don't need to clean the entire MAF housing.
    You need to undo the two star-shaped screws to remove just the MAF sensor itself. You will then have access to clean the small evaporation plate (strip of metal) with isopropanol and a cotton bud.
    Hope that helps - Alex.
  4. Re: Clean your Air Mass Sensor !!!!!
    #24
    Hi I have an AUdi A4 1.8 1998, idle all over place, can you tell me how to clean the MAF if you think this will help? Thanks
  5. Re: Clean your Air Mass Sensor !!!!!
    #25
    Jul 2007
    Mine have failed the MOT thet had to turn off the emission testing equipment to stop it getting damaged, Is the MAF Easy to fit and in view under the bonnet. And a silly question I downloaded a cataloge for cats (not the animal) and it said Audio A6 2.0 with out cat, how do I know if my car has a cat converter ? I really know nothin anout cars
    Quote Originally Posted by clogman View Post
    Ah but....
    I tried the same trick, fixed the car up a treat (I thought) then it failed its MOT because emissions were all over the place.
    Fitted a new MAF (exchange unit from Audi for about £60) and all the emissions fell back to very low levels and the car ran sweet as a nut.
    Hope a simple clean works for you, shame it didn't for me in the long run.
  6. Re: Clean your Air Mass Sensor !!!!!
    #26
    I have an 1998 2.4 V6 Petrol and I'm experiencing eratic idling. Could this be the Air mass sensor and if so what does it look like.
  7. Re: Clean your Air Mass Sensor !!!!!
    #27
    I use to own a nissan primera and the maf also use to get gunked up. The guide for that recommended to spray carb cleaner on the metal strip. It can up bright silver, just had to make sure it had dried before refitting.
    Could I use carb cleaner on my car now? It's a Passat B5.5 1.8t.
  8. Re: Clean your Air Mass Sensor !!!!!
    #28
    Hi can you help me, how can I clean my MAF? I own a 1999 Passat 1.8T AEB. It's happening the folowing:
    In first gear it would rev to 5000rpm and then cut out
    On hard acceleration the (3rd gear and above) the engine will not rev beyond 4000-4500 rpm. It does not feel like a misfire, just as if the rev limiter has cut in early.
    Think it might be the MAF?
    Any Help?
  9. Re: Clean your Air Mass Sensor !!!!!
    #29
    dublin ireland
    tell me how.........my good man
  10. Re: Clean your Air Mass Sensor !!!!!
    #30
    Quote Originally Posted by Killerwhat? View Post
    Hello everyone I'm a Forum newb!
    Do any of these sound familiar:
    • Unstable idle
    • Hesitation between gear changes
    • Flat spots
    • Engine speeds up when you lift off - yes really !
    • Throttle 'hangs' between changes
    • Missfire above 4000
    Well. I've scoured the forums for something definitive on all the above which have plagued my s/h (125 k) A6 1.8T Avant (petrol) since I bought it a year ago. So I finally bit the bullet, took out its Air Mass Sensor (often referred to as the MAF) and cleaned it.
    What a transformation , it finally feels like the car I always thought it should have been !
    Want to know how ? reply to this thread, it took me about an hour.
    Cheers !
    Hi any chance of mailing me the instructions so i can have a go
  1. EGR clean out
    By VEEDUBYA in forum Passat - Archive Topics
    Last Post: 01-11-2007, 09:28 PM
  2. Intercooler clean out
    By M4YTY in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-05-2007, 09:06 PM
  3. What do you use to clean your car?
    By Eshrules in forum Chat - Anything with wheels
    Last Post: 02-04-2007, 08:03 PM
  4. Why replace it when a clean does the trick?
    By Bofs in forum Passat - Archive Topics
    Last Post: 18-01-2007, 06:48 PM
  5. air mass sensor problems
    By keithg in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 18-11-2006, 06:52 PM
