Thread: Tiptronic gearbox fault
  1. Unhappy Tiptronic gearbox fault
    Feb 2007
    Hi, I'm a newbie on the forum, but I've been running Audi's and the like for many years..........
    I need some advice - my wife's A6 Avant 2.8 (1999) has developed an intermittent fault, which I think(!) stems from the gearbox.
    Very occasionally the cars stutters when accelerating from relatively low speed ~ 30mph+. The sensation is almost as if the gearbox is trying to change down a gear, but can't find it! This lasts seconds and then normal progress resumes.
    The fault only ever shows itself as low rpm ~ 1400 rpm - when the car has got itself into a high gear (possibly 4th) and then as traffic speed picks up, the stutter appears as more acceration is required!
    Manual selection seems fine? Engine revs round the full working range ok, and I've never notice a problem when making progress.
    Is this a common fault? Will it get worse......... I hope someone can offer an insight into this annoying (and potentially worrying!) problem.
    Kind Regards
    Quote Originally Posted by ProfDMW View Post
    Kind Regards
    are you absolutley sure this is a gearbox issue and not MAF related?
    Feb 2007
    I might be sounding dumb, but how would I spot the difference?
    Nov 2006
    Swampyland, UK
    Get the fault codes read. It is pointless trying to diagnose Tip probs without them.
    Rgds
  5. Re: Tiptronic gearbox fault
    Kind Regards
    did you find out what the problem was?
    My A4 Avant 2.5 tdi has the some problem
    many thanks
  1. tdi tiptronic
    By tdi guy in forum Chat - Anything with wheels
    Last Post: 10-04-2007, 12:32 PM
  2. Replies: 3
    Last Post: 24-03-2007, 11:11 PM
  3. T Reg Passat - Electrical Fault, Remote Central Locking Fault
    By adriana in forum Passat - Archive Topics
    Last Post: 01-03-2007, 06:27 PM
  4. mutitronic gearbox fault
    By andybrod in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-06-2006, 09:28 PM
  5. Auto gearbox fault on A4 2.5TDi
    By bully in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-06-2006, 09:18 PM
