Thread: Brake warning light with the beeps
  1. Brake warning light with the beeps
    eclipsetbs Guest
    2000 Audi A4 1.9TDI with 100,000+ miles. Super, well-maintained car. Comes on for 2 secs at start-up only. Checked the brake fluid level - OK. ABS warning light does not come on any time. All brake pads and discs replaced recently. Car parked at home facing up a small slope. Is it likely to be a cold weather thing related to the fluid level sensor (or something else). I feel it's something simple, because there is are no problems driving and braking (not tested it hard on wet roads though. Do owners sometimes remove ABS fuses to pass MoTs, ie the ABS does actually have a minor problem (I'm a bit cynical sometimes!? Any ideas? Dave
  2. Re: Brake warning light with the beeps
    eclipsetbs Guest
    Wow! I'm overwhelmed by the response guys. Never mind, I've found my way around the forum and learned enough I think from other posts to make a start....
    I'll try to eliminate the phenomenon by taking the following steps in sequence:
    Check the tyre pressures OK, probably not necessary, but I'll do it anyway, 'cos it's not been done for a while.
    Top up the brake fluid level just that bit more (the level sensor can be a bit sensitive to moisture in damp, cold weather esp. if on a slope).
    Charge the battery (it's a pain getting to the brackets, but what the hell) - and replace it if necessary.
    Get behind the front wheels (if my back will take it) to check the connectors to the sensors to the inner pads.
    Get Audi to do their standard relay 'fix' for this apparently known issue.
    Hope this clarifies everything, without having to spend an hour searching for the answers, for those with the same problem. Dave
    Wad some power the gift to gie us,
    To see ourselves as others see us!
  3. Re: Brake warning light with the beeps
    Jan 2008
    take the cover off your light and check for any water/moisture on the black plastic the blubs plug into. should be some what the same ot mine.
    if its damp dry it out and reseal and lamp. that was my issue, simple fix
  4. Re: Brake warning light with the beeps
    eclipsetbs Guest
    Thanks Diesel -a4, but I believe the sensors and associated electronics are controlling supplies to the warning light blubs integrated into the dashboard (and there are no damp/condensation problems). I'm not inclined to rip out the dash so I'll proceed as I planned thanks, Dave
  1. Flashing colant light and no brake warning light
    By cookie7354 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 19-09-2008, 11:24 PM
  2. 3 beeps on dash flashing brake and ABS light on.
    By Leon Fletcher in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-04-2008, 01:01 PM
  3. DIS Brake Fluid Warning with ABS warning light
    By radar1022 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-04-2007, 10:42 AM
  4. Brake fluid warning light with ABS light
    Last Post: 02-04-2007, 03:28 PM
  5. Brake Warning + 3 beeps
    By MarkBS in forum Audi A4 - Archive Topics
    Last Post: 29-03-2007, 11:13 PM
