Thread: Steamy Windows
Results 1 to 10 of 16
Hybrid View
  1. Unhappy Steamy Windows
    Feb 2007
    Right i bought a 97 A4 1.9 TDI SE 110 and the heater only ever put out luke warm air at best i did a flush of the system in case the heater matrix was blocked i refilled with coolant now if i put the heater on at all it just steams up the windows in the car i have to drive round with the the temp set on lo and everything is fine but as soon as i turn the heat up to even 18 O/c it gives out a puff of smoke through the vents and it,s steamy windows time again There's a faint smell thats like hot rubber but the system does not seem to be airlocked.
    Am i missing something
    Please Help
    I am freezeing!!!
    Feb 2007
    UK (London)
    You have a leak hence the steam.
    04 Audi A4 B6 1.8TQ S-Line 190bhp 6 Speed Duel SMIC
    Milltek Exhaust|VMR boost Gauge|SP51 K04-15 Outlaw (K04-23+)|Samco Sport DV|034 Sport CAT|
    To be fitted: B7 RS4 F-Brakes|B5 RS4 R-Brakes|SB Stage4| TT MAF| 380 inj|
    Feb 2007
    Would that cause the smell as well!!
    Feb 2007
    UK (London)
    Quote Originally Posted by Big Bad T View Post
    Oh yes and you may note you are lossing some water as well.
    Feb 2007
    Feb 2007
    glasgow
    It sounds like the matrix is leaking this would account for the smell and the steam.M
  7. Passat had same problem
    Feb 2007
    Sarajevo Bosnia
    Bad news dude. I had a 1990 passat that I flushed the rad and the same problem happened. Steam from the vents and fogged up windows and nothing but cool air. I froze as well for a couple of weeks. What obviously happened was the flush flushed out all the rusty crap that was sealing possible leaks as the car was rather old and when they were freed thus the leaks. My heating radiator (the small one just inside the dash) had to be replaced.
    My solution was the dashboard was stripped apart and a new rad installed.
    Hopefully the Audi is easier to fix. Should be one would think.
    Good luck
    Dave
    Feb 2007
    Thanks for all the help
    Feb 2007
    UK (London)
    May be some Rad weld might work.
  10. Good point
    Feb 2007
    Sarajevo Bosnia
    Quote Originally Posted by docurley View Post
    Depending on where the leak is rad weld may work. No sense going to extremes when there could be a quick long term solution.
    Had an 81 Camero Z28 that developed a rad leak (again after a flush) and rad weld did the job just fine. Saved a bundle by not having to replace the rad.
    Dave
  1. Electric windows
    By Rick Jay in forum Touran - Sharan - Caravelle
    Last Post: 01-03-2010, 01:14 PM
  2. Steamy windows
    By Vic Young in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-01-2009, 10:50 PM
  3. steamy sharan
    By andy e in forum Touran - Sharan - Caravelle
    Last Post: 29-01-2007, 09:07 PM
  4. Windows Will Not Go Up!
    By Munders in forum Passat - Archive Topics
    Last Post: 11-01-2007, 09:20 PM
  5. steamy windows
    By Ian Mac in forum TT - 8N Forum - 1998 - 2006
    Last Post: 22-11-2006, 12:28 AM
