Thread: Brake lights and main beam not working!
Results 1 to 10 of 13
  1. Brake lights and main beam not working!
    Hey everybody as above,
    Have checked the bulbs for the break lights and both seem fine. Could it be the switch under the brak pedal?
    Main beam - when i flick the main beal on it switches the lights off completely.
    Any help at all greatly appreciated.
    Thanks, Matt
  2. Re: Brake lights and main beam not working!
    Dec 2007
    8 Post(s)
    Quote Originally Posted by mattyc94 View Post
    Thanks, Matt
    As you suggest the brake light switch would be first
    to check after eliminating any fuse /bulb problem
    Main beam problem=check bulbs/fuses
    I remember someone with similar problem had switch fault
    and it was cured by a spray of wd 40
  3. Re: Brake lights and main beam not working!
    Cheers for the reply.
    Thing with the main beam - has never worked since i got the car a few months ago. When I looked in the fusebox the place for the main beam fuse had no fuse in it!
    Seems to be one of the larger square fuses (top right hand corner of fusebox)
    Can anyone confirm if this is the correct fuse and what type it is?
    Cheers, Matt
  4. Re: Brake lights and main beam not working!
    Dec 2007
    8 Post(s)
    Cheers, Matt
    As per handbook for Audi 80
    Fuse layout from left to right
    no 8=High Beam Headlight right/warning lamp
    no 9 High Beam Headlight left
  5. Re: Brake lights and main beam not working!
    Hi there,
    OK pulled the undertray off from under the steering wheel to look at the switch at the back of the brake pedal. And to be honest I really dont know what I'm looking for.
    So...I've taken a few photos, can anyone help me out!?
    P.S. the brake pedal is the bar in the middle
  6. Re: Brake lights and main beam not working!
    Dec 2007
    8 Post(s)
    Hi there,
    The brake light switch is one of these ok but I would be reluctant to advise to bridge contacts here as one of the units
    is probably connected to ecu and bridging cables could possibly cause harm. I will at a later stage (few days)confirm which unit is the
    actual brake light one and come back to you
    In the meantime someone else may reply
  7. Re: Brake lights and main beam not working!
    Hey Michael,
    Cheers for replying again, if you could find out which one the switch is it would be greatly appreciated!
    Anyone any idea what could be causing the main beam to malfunction? Bulbs are definitely fine.
  8. Re: Brake lights and main beam not working!
    Dec 2007
    8 Post(s)
    Hey Michael,
    Hello Matty. Had a look at switches today.
    it appears that largest of the two is the brake light switch
    the highest one. What I found is that there is power to the yellow/red cable when ign was on. when pedal is pushed it allows the live to continue to the black/red cable.
    Hope this helps
    As regards the Headlight problem with bulbs eliminated as cause. You could check to see if you have power at the two fuses. You can do this with multimeter or tester with light and probe. there is normally a small bit of metal contact on the fuse
    where you can test same. If you get no joy from this test I may try to follow power path on similar model to assist.
    Am I right in assuming that the h/lights do not work when you
    keep lever pulled out as for flashing?
    If it is a switch problem it is not too difficult to replace
  9. Re: Brake lights and main beam not working!
    Flip me you've gone to alot of trouble, thanks again!
    Thats a great help, will give it a blast hopefully this weekend and get a new swicth if needs be.
    Thanks again, Matt
  10. Re: Brake lights and main beam not working!
    Slight progress on the main beam situation - battery shat itself and the car wouldnt jump ( was in an underground car park of a hotel) and couldnt bump start.
    Anyways...while the RAC man was there I asked hom to check the main beam issue...as Michael suggested he checked the fuses and all were fine. he says hes 95% sure it'll be the a connection at the actual stock, failing that it'll be the relay.
    Starting to get somewhere now...need to get a weekend at it and get the thing sorted! MOT coming up in a few weeks, nightmare!
  1. Faulty main beam
    By golding25 in forum Polo - Derby - Lupo - Fox
    Last Post: 20-09-2008, 09:54 PM
  2. changing main beam headlights
    By alienkidmj12 in forum Passat - Archive Topics
    Last Post: 19-12-2007, 07:19 PM
  3. Fog lights+Main beam HID?
    By tony_anon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-10-2007, 05:41 PM
  4. Near SIde Main Beam STopped Working
    By markb1 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-05-2007, 10:21 AM
  5. Near SIde MAin Beam Faulty
    By markb1 in forum Archive posts
    Last Post: 11-05-2007, 11:30 PM
