Thread: B & O upgrade
Results 11 to 20 of 24
  1. Re: B & O upgrade
    Mar 2008
    Devon
    Quote Originally Posted by AndyH123 View Post
    I've got a WD Passport drive in mine too (see my thread on using USB with AMI).
    Andy
    It was your original post that persuaded me to go the USB route as opposed to buying an iPod.
  2. Re: B & O upgrade
    May 2008
    Quote Originally Posted by JohnH99 View Post
    Currently there are around 4500 files on it taking up around 20 GB mostly 192kbps WMA. Audi quote that MP3, WMA and AAC are supported but I had problems with AAC but MP3 and WMA worked fine.
    Will it detect/recognize playlist files (like *.m3u)?
    And is there a file number limitation (like there is for the SD cards)?
    I've never seen the drive light go off, but I'm pretty sure the car is looking after itself.
    Andy, is your WD Passport also a WD250ME, or another model?
    Ben
    2009 Audi A4 2.0T S-Line Avant / 2008 Audi TT 2.0T S-Line Coupe
    Retired: 2003 Ford SVT Lightning / 2001 Ford SVT Lightning / 1993 BMW 740iL / 1990 BMW 535iM / 1986 Porsche 944 Turbo / 1983 Porsche 944
  3. Re: B & O upgrade
    Mar 2008
    Mine is a WD1500XMS-00
    I've got about 80Gb of 192kbps .wma on there. Not sure how many files that is, but it copes fine. Just gets a little slow when navigating back to the root and if you scroll through the A-Z list very quickly.
    I think playlist support is limited to the iPod, but I haven't really gone to town with trying different extensions
  4. Re: B & O upgrade
    May 2008
    Hmm, it looks like there are 2 different types of USB cables for AMI. I suppose one is a female receptacle, and the other is male? Or are they different size USB connectors?
    Which one is needed for the WD Passport drives?
    Ben
  5. Re: B & O upgrade
    Mar 2008
    Quote Originally Posted by BMWBig6 View Post
    https://www.vwaudiforum.co.uk/forum/s...ad.php?t=43095
    Different sizes:
    Full size USB - part code 4F0051510G
    Mini USB - part code 4F0051510H
    Some more details in the thread.
  6. Re: B & O upgrade
    Mar 2008
    Devon
    According to the manual:
    Maximum of 119 playlists, no more than 1000 entries per playlist. Formats supported, M3U, PLS and B4S
    As for file numbers:
    Maximum of 500 files per directory with the directory structure limited to a maximum of 7 subfolders. Doesn't mention a limit on the number of directories.
    For connecting to the AMI, the passport drive uses a mini USB connector.
    Have a look at Andy's thread for much more detail.
  7. Re: B & O upgrade
    #17
    May 2008
    OK, thanks for the detailed info. If I am reading everything correctly, it looks like the mini USB connector is required for the WD Passport drive, but the full size USB is more useful for flash drives, etc.
    Ben
  8. Re: B & O upgrade
    #18
    May 2008
    Found the AMI/USB cables in the Audi accessories collection, but it says:
    USB Cable for AMI
    Item Number: 4F0051510G
    Mini USB Cable for AMI
    Item Number: 4F0051510H
    USB Cable to integrate Audi Music Interface (AMI) with your MP3 player. This cable transmits audio signals only, no content is displayed on the MMI screen.
    Is that correct? I thought I read that artist/title (and other ID3 tag info) was displayed.
    Ben
  9. Re: B & O upgrade
    #19
    Mar 2008
    Devon
    The display depends on whether you have the display details option checked. If it not checked you get a track / filename listing in the MMI display that you can scroll through and the folder title (album name?) is displayed at the top. Scrolling up you will see an "up" icon which takes you up a level.
    If the details option is checked you get a pop out window on top of the track list that displays the artist name, album name and track title.
  10. Re: B & O upgrade
    #20
    May 2008
    Ah ok, I got worried that it would be like the "old" AMI (that only displays Track 23, Track 24, Track 25, etc.). Thanks for confirming for me (the Audi website is obviously not 100% accurate).
    I apologize for hi-jacking this thread with so many questions about the AMI/USB interface, but I have one more question. Approximately how long does it take for the WD Passport HD to spin up when you start the car? If you turn on the car, does the stereo immediately resume playing the song where it left off when you last turned off the car? Or does it take several seconds for the drive to spin up and for the stereo to "seek" the appropriate track on the drive? Or does it lose its place and play the first song in the first folder every time you start the car?
    Ben
  1. Please Help MMI Upgrade
    By pairey in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 08-07-2009, 08:59 PM
  2. Sat nav upgrade
    By Greengoblin in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-06-2008, 06:58 PM
  3. T5 Upgrade
    By kustom in forum The Commercial Range
    Last Post: 17-04-2008, 05:22 PM
  4. k04 upgrade
    By 1.8t bus in forum Chat - Anything with wheels
    Last Post: 23-03-2008, 01:02 PM
  5. A4 ecu upgrade
    By neil john in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-06-2007, 09:31 PM
