Thread: Audi A6 Avant (04 plate) service info
  1. Audi A6 Avant (04 plate) service info
    Nov 2008
    Morning guys
    Quick question - My wife just called and said our Audi A6 Avant (04 plate) has a warning saying the service is due in 50 miles ( I never drive it ) and am due to travel on business from this evening, therefore I wondered if you had any info on what service is needed - Imagine it must be around the 50k mile mark now..
    Any info greatly appreciated...
  2. Re: Audi A6 Avant (04 plate) service info
    Jul 2007
    Cheshire, or my A6
    Quote Originally Posted by mattey View Post
    Morning guys
    If the timing belt has not been done its probably best to get it done now, it is 4 years or 60k whichever comes first, but better safe than sorry.
    Do you know what was replaced at the last service?
    A pollen filter, air filter and oil filter and oil replacement is standard on a service, but if the fuel filter wasn't done last time then it will need replacing this time.
    Use the service as an opportunity to check for blocked drain holes beneath the battery, that can cause horrendous problems with the CCU and leave you with a big repair bill. Also check when stationary, on full lock left or right, that there is no clattering/squeeling noise of some sort, if there is, you will need to replace the alternator pulley bearing, as the A6s use a one way clutch on the alternator.
    Paul
  1. 2005. A4 20.T FSI avant info
    By skull666 in forum VCDS - General Questions
    Last Post: 10-08-2008, 11:31 PM
  2. Passat service...anyone want info?
    By m4xmw in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-04-2008, 05:33 PM
  3. audi 80 avant M plate
    By thepoynt in forum 80 - 90
    Last Post: 29-03-2008, 10:45 AM
  4. 120k service info?
    By wid77 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-09-2007, 08:59 PM
  5. How to re-set Service Interval for 2000 Audi A6 1.8T SE AVANT?
    By fsazhar in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 05-02-2007, 04:14 PM
