Thread: shocks
  1. shocks
    Do you need to change shocks as well if you use say 30mm lowering springs.
  2. Re: shocks
    Sep 2008
    Dundee
    i think up to 40mm is ok with the same shocks
  3. Re: shocks
    galway ireland
    Its up to you if stiffened lowered springs with original shock are still too soft then you'll want stiffer shocks to get the desired result but when lowering you will need to have the camber adjusted, and if the wheels are bigger then original you will have to shim / pack the bump stop to make sure that the top of the wheel doesn't catch the wheel arch when cornering (front wheel sticks out and body roll compresses the shock on the outside of the corner).
    Personally the hassel in lowering a car/van propperly along with not being able to corner as hard just isn't worth the improvement in apearance.
    but thats only my opinion.
  4. Re: shocks
    Its on 2006 caravelle and vw sell springs 30mm less than original ,but doesn,t mention shocks .
  1. 2.0 SE Rear Shocks
    By torchy303 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-04-2008, 09:28 AM
  2. rear shocks
    By mikeya4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-04-2008, 09:47 PM
  3. Shocks
    By avantscott in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 19-03-2008, 01:22 PM
  4. shocks
    By vwray in forum Golf MK4 - 1999 - 2004
    Last Post: 22-01-2008, 11:22 PM
  5. shocks
    Last Post: 12-01-2008, 07:46 PM
