Thread: Can't find part.. problems starting hot
  1. Unhappy Can't find part.. problems starting hot
    Nov 2008
    Its obvious when you open the boot there is a hose missing.. I just have no idea what its called and so can't find a replacement anywhere and i've been looking for hours!
    Here's a pic of a similar engine.. its the hose on the left side of the pic going from the air filter round the front of the engine.. and has a valve or something on the filter end
    http://volkswagenspares.com/UserFile...tom)%20(2).JPG
    I'm guessing (probably very innacuratly) its causing problems starting hot.. no other problems atall that i've noticed.. !
    I'd be grateful for what its called or where i can find a replacement!
  2. Re: Can't find part.. problems starting hot
    134 Post(s)
    1994 Post(s)
    Boot? Bonnet.
    The hose that is missing is the hot air pre heat hose and it is there to pre heat the air to the injection system to prevent icing in very cold running so this will not affect hot starting, that is usually down to a faulty coolant temperature sender so I suggest you have the engine ECU scanned for fault codes at a garage. What year and engine is in your Golf 3? I am guessing at something around 1993 and a 1.4 so an ABD code engine. The hose from the exhaust to the air cleaner for a 93 1.4 with the early air cleaner is VW number 028 129 087 A and costs about £14 from VW. The hissing noise is probably from a split inlet manifold brake servo hose but you need to get this inspected at a garage.
  3. Re: Can't find part.. problems starting hot
    Nov 2008
    Thanks for the reply.. that was just an example picture.. I have a 97 golf 1.6, Engine AEE, how would i find the part to buy with that ref number?
    the hot starting isn't a massive problem.. I'll wait till the MOT in Jan to get the ECU checked out!
    Sorry I'm a complete amateur..
  4. Re: Can't find part.. problems starting hot
    134 Post(s)
    1994 Post(s)
    For a 97 AEE the hose is part number N 907 338 04 which is available from a VW dealer for about £16.
  1. Replies: 2
    Last Post: 22-09-2008, 08:47 AM
  2. Problems starting
    By Springer in forum TT - 8N Forum - 1998 - 2006
    Last Post: 08-02-2008, 02:06 PM
  3. 1998 Leaking Issue. Part Cause and Part Fix
    By 1998FTW in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-06-2007, 03:10 PM
  4. Need a part I can only find in UK.... thanks for looking.
    By deephouse in forum Audi A4 - Archive Topics
    Last Post: 05-02-2007, 08:11 PM
  5. Audi part numbers - where to find?
    By djneils98 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 05-02-2007, 06:07 PM
