Thread: Braking Buzz!
  1. Braking Buzz!
    Feb 2007
    Hi There,
    I'm experiencing a weird problem with my Passat (2000 TDi 110), where the brake pedal is buzzing at my feet when braking from slow speeds.
    If I am doing around 5-10mph and lightly apply the brakes, it sometimes buzzes in the peddle and I can't apply full pressure (this can be tricky when behind another car!), but if I take my foot off the pedal or wait around 3 seconds, the buzz and pressure restriction goes and then I end up braking quite sharp as the pressure releases. The buzz is quite audiable and can be heard by others in the car and sounds quite electronic. Pads and Discs are fine, they will need replacing soon, but this issue has been going on for a while, so I don't think it's related to them.
    Has anybody else come across this, or have an incling as to where I need to look?
    Thanks,
    Rob
    Oct 2005
    Lutterworth
    It's a dirty or faulty abs sensor.
    When the car is going slowly its output drops off so the abs thinks that wheel is locked.
    Use VAGCOM to read the sensor outputs as you move the car slowly to identify the duff one.
    Passat Estate 2002 PD130
    Passat 1.8SE 1998
    Oct 2005
    Lutterworth
    Quote Originally Posted by Andy B8 View Post
    Do you get any warning lights? as i do not.
    No there are no check lights, it is not detected as a fault.
    You need to take a more analytic approach rather than throw parts at it.
    If you already have a laptop then a copy of VAGCOM at 100usd + a cable from eBay at less the £20 will give you a better way of fixing it.
    In terms of parts, have you looked at the abs toother rings that provide the impulses to the sensors ?
    Passat 1.8SE 1998
  1. A6 Smoking Exhaust on Braking
    By John McCavert in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 25-05-2009, 10:32 PM
  2. Single knock when braking or accelerating...
    By dieselmonkey in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-08-2007, 04:05 PM
  3. Serious Braking Problem
    By rapster01 in forum Archive posts
    Last Post: 03-03-2007, 11:07 PM
  4. Audi 80 avant TDI braking problems
    By rapidresto in forum 80 - 90
    Last Post: 19-02-2007, 06:30 PM
  5. cracking sound when braking
    By arena432 in forum Chat - Completely Off Topic
    Last Post: 14-07-2005, 05:19 PM
