Thread: DIS AND CRUISE RETRO FIT b6+b7
Page 14 of 16 FirstFirst ... 41213141516 LastLast
Results 131 to 140 of 159
  1. Re: DIS AND CRUISE RETRO FIT b6+b7
    Sep 2011
    Shannon, Ireland
    Many thanks to everyone contributed to this thread! I've just successfully installed DIS and cruise control on my A4 B6 following instructions found here all I have left to do is to make 'water feature' in the centre of the dash to work as it supposed to, parts have been ordered.
    Cheers!
    Ruslan
    2001 Audi A4 2.0 20V
    1995 VW Polo 1.05-sold
    Mod's so far: cruise control and DIS retrofitted, two cup holders in dash
    Mod's to come: ESP switch and card holder relocation, color DIS, extra lighting
  2. Re: DIS AND CRUISE RETRO FIT b6+b7
    Mar 2009
    Montenegro
    13 Post(s)
    Hi All,
    Sorry for recalling this thread,
    I have just installed cruise control with module 8E0 953 549 Q from Audi B7 2007year to my car Audi A4 B6 2004 year, it's working fine.
    I have intention to install MFSW as well but old type (b6 type single stage airbag) as soon as I find it.
    My question is : will this sc module support old style multifunction steering wheel (as it is from new model B7) and will be possible to use sds with this steering wheel as on below picture?
    One more question, is it possible to use steering wheel from Audi A6 or A8 which looks like this one and appropriate slipping ring?
    Thanks for the replies,
    Regards
    Novica
  3. Re: DIS AND CRUISE RETRO FIT b6+b7
    May 2007
    knee deep in clunge
    14 Post(s)
    the slip ring differs for b6 and b7 single/dual airbag but apart from that q should work with b6 mfsw and sds
    Steering control unit with revision M or P support b6 mfsw
    Slip ring for b6 8e0 953 541e
    The wheels from a8 should be fine however you will need to alter the loom for the b6 steering control unit as a8 differs, best be is to find a B6 unit to save the hassle
  4. Re: DIS AND CRUISE RETRO FIT b6+b7
    Mar 2009
    Montenegro
    13 Post(s)
    Quote Originally Posted by a8 tech View Post
    Hi A8 Tech and others,
    As you are already aware, I have RNS-e installed by factory (on my Audi A4 B6 2004) and recently I have installed oem BT for phone. I have already installed CCS with processor 8E0 953 549 Q. All is functioning OK. Now I want to have control of radio and phone on my steering wheel. At this moment I can find and buy MFSW for B6 model (as I do not want to retrofit B7 MFSW) with these symbols "<" and ">" instead of the symbols "R/T" and symbol of phone handle (like on above pictures). As I am inpatient and want to buy it, can somebody tell if first buttons (< & >) can work with phone and if SDS can be used with these buttons?
    It looks like this:
    Steering Wheel Airbag Air Bag 02-03 Audi A4 A6 S6 A8 S8 B6 C5 - 8E0 880 201 AB | eBay
    Thanks in advance
    Novica
  5. Re: DIS AND CRUISE RETRO FIT b6+b7
    Feb 2009
    I fitted a heated steering wheel from an A8 (used) had to use the control box from an a4 though (is ib the wheel itself) and as far as I can remember I had to buy a new wiring loom for inside the wheel.
    W.
    Sent from my ASUS Transformer Pad TF700T using Tapatalk 2
  6. Re: Mfsw, dis and cruise retro fit b6 & b7 a4
    Apr 2013
    ireland, KILLARNEY
    hi a8 tech wondering I have steering ecu ending with F which doesn't support cc, if I change the ecu do I need to change the slip ring too? and any chance you could show me wiring cc to ecu any pic??? please and thanks.. audi a4 2004 avb engine
  7. Re: Mfsw, dis and cruise retro fit b6 & b7 a4
    Jul 2011
    Kilmarnock, Ayrshire, Scotland
    My car 2004 Avant came with factory fitted CC & auto wipers I have since added the stalk for the Dis, I have tried to get it coded however Audi here in Germany are telling me that the car cant simply be coded (they haven't tried) if this is true what else do I need to change or are they talking rubbish as I don't have vagcom or any connection to anybody that does have it I cant check it. Anybody in the Paderborn area who could / who wish's to help please get in contact.
    2008 A4 B8 Avant 143 2.0 TDI & 2014 Skoda Superb Comb 4x4 170CR 2.0 TDI DSG
  8. Re: Mfsw, dis and cruise retro fit b6 & b7 a4
    Apr 2013
    ireland, KILLARNEY
    follow this link Trip Computer Retrofit but it would be pointless if u don't have vag-com dude but ur case is simple as u have right multi function steering ecu I fking don't. bs quit angry with such stupid little details between same car diff year one has it the other one doesn't why not?
  9. Re: Mfsw, dis and cruise retro fit b6 & b7 a4
    Jul 2011
    I have done everything on the post above apart from the coding & wiring up the washer level sensor it is in place just waiting until it is coded before connecting in up. My problem is that Audi are saying it cant be done (no reason give why it cant be done) as I don't have VCDS to complete the Mod, I have no way to prove if it can or cant be done.
  10. Re: Mfsw, dis and cruise retro fit b6 & b7 a4
    Feb 2013
    Swindon
    Rab
    If your steering module (SCSM) is working with cruise control then it can do DIS, as described here http://wiki.ross-tech.com/wiki/index...tting_%288E%29. Sounds like Audi are just fobbing you off!
    I just retrofitted Cruise to mine. Had to change the SCSM and add the Cruise stalk. Coded myself, using the codes generated here http://dl.dropbox.com/u/8970502/VAG-...ctivation.html. Obviously, you will need VCDS. I have a unofficial cable from ebay (£20) and a registered version of VCDS Lite (£68). Worth the investment if you plan on keeping your Audi as it's an incredibly useful tool.
    demiari
    No need to change the slip ring, just the SCSM (steering ecu as you call it ) and add the Cruise control stalk. Then code as above.
  1. retro fit cruise
    By mike cosker in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 31-10-2008, 11:55 PM
  2. Question retro fit cruise control
    By Mr.I Kenney in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-07-2008, 04:18 PM
  3. Retro Fit Cruise Control
    By gazza007 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 30-04-2008, 09:05 AM
  4. Retro fit cruise control
    By PeteK in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-04-2008, 12:06 AM
  5. Retro fit A3 Cruise control
    By alibla in forum Audi A3 - Archive Topics
    Last Post: 30-05-2007, 10:59 PM
