Thread: DIS AND CRUISE RETRO FIT b6+b7
Page 10 of 16 FirstFirst ... 89101112 ... LastLast
Results 91 to 100 of 159
  1. Re: DIS AND CRUISE RETRO FIT b6+b7
    #91
    Nov 2010
    Chorley, Lancs
    Brilliant - thanks. How do i get in contact with you?
    Regards
    Dan
  2. Re: DIS AND CRUISE RETRO FIT b6+b7
    #92
    May 2007
    knee deep in clunge
    14 Post(s)
    send private message
  3. Re: DIS AND CRUISE RETRO FIT b6+b7
    #93
    Feb 2010
    staffordshire
    Quote Originally Posted by ROMEYR32 View Post
    Regards
    Dan
    Jon (a8) fitted mine last year , he knows what he is doing trust me i think he can do this blindfolded and one hand behind his back
    Full vcds HEX-USB-CAN Interface available in the staffordshire area PM me
  4. Re: DIS AND CRUISE RETRO FIT b6+b7
    #94
    Nov 2010
    Chorley, Lancs
    Thanks for that, i`ve been in touch! Cant believe mpg isnt standard fit!!
    Dan
  5. Re: DIS AND CRUISE RETRO FIT b6+b7
    #95
    Mar 2009
    Kidderminster, Worcestershire and Tewkesbury, Gloucestershire
    Guys can you help?! See https://www.vwaudiforum.co.uk/forum/s...694#post611694
    At the w/e fitted my cruise and DIS. Q version SCSM which should support the two, all set up and working so far as I can see. Cruise is working fine but nothing from DIS.
    The Part I used was 4E0 953 503 G4PK, supplied by TPS tho I was under the impression I should be using C4PK.
    No fault codes registered.
    I coded it 00042, which is avant (rear wiper) with on board computer and cruise.
    Anyone any ideas?
    All the ABS system is set up. I've followed the instructions. I have the faults/code log if that's a help.
    I'm annoyed the DIS cost me £80 and the Cruise £30, the cruise works and DIS doesn't!
    2007 A6 2.7TDi Avant Manual S-Line
    2003 A4 B6 Avant 1.9 TDi Quattro Sport, Manual -Sold
    1999T A6 C5 Avant 2.5 Auto, 244k -Sold
    2005 STM Phoenix R1 powered, 1988 205 Gti 16v tarmac rally car . . and a few motorbikes
  6. Re: DIS AND CRUISE RETRO FIT b6+b7
    #96
    May 2007
    knee deep in clunge
    14 Post(s)
    for dis you need to add the code change in address 16 for dis
    also you need to change adaption channel 19 in address 17 to enable the function
    make sure you earth pin 1 blue connector on the back of the dash to fool the washer level low signal
    post all code for address 16 and adaption channel 19 in address 17
  7. Re: DIS AND CRUISE RETRO FIT b6+b7
    #97
    Aug 2009
    largs scotland
    Can anyone recommend someone to do this in Scotland (i am in ayrshire).
  8. Re: DIS AND CRUISE RETRO FIT b6+b7
    #98
    Mar 2009
    Thanks, but sorry A8 you've lost me!
    Add 16 should be 00042?
    Add 17 Adpt 19 should be?
    I'm using 409.1
    Does the quattro make a difference due to the tank size?
    this is what i have at the moment, the steering wheel is done I believe 00042 is correct for cruise and DIS on an avant
    Address 16: Steering wheel
    Controller: 8E0 953 549 Q
    Component: Lenksáulenmodul 0801
    Coding: 00042
    Shop #: WSC 00672
    No fault code found.
    Address 17: Instruments
    Controller: 8E0 920 950 J
    Component: KOMBI+WEGFAHRS. RB4 D36
    Coding: 01400
    Shop #: WSC 00001
    WAUZZZ8E13A347611 AUZ6Z0C0016661
    1 Fault Found:
    00779 - Outside Air Temp Sensor (G17)
    30-00 - Open or Short to B+
  9. Re: DIS AND CRUISE RETRO FIT b6+b7
    #99
    Mar 2009
    sorted, I hadn't coded the instruments to support DIS
    my Existing code was 30100. using the noted in this thread i tried 31200 but that came up as an error so I used 31000 and that worked fine. All working now other than the pesky water bottle empty light, but that will soon be sorted.
    Thanks for the help,
    Phil
  10. Re: DIS AND CRUISE RETRO FIT b6+b7
    Southern County Softy
    20 Post(s)
    A8 saves the day... well done Phil
    A4 2.5 tdi QS (mapped)
  1. retro fit cruise
    By mike cosker in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 31-10-2008, 11:55 PM
  2. Question retro fit cruise control
    By Mr.I Kenney in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-07-2008, 04:18 PM
  3. Retro Fit Cruise Control
    By gazza007 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 30-04-2008, 09:05 AM
  4. Retro fit cruise control
    By PeteK in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-04-2008, 12:06 AM
  5. Retro fit A3 Cruise control
    By alibla in forum Audi A3 - Archive Topics
    Last Post: 30-05-2007, 10:59 PM
