Thread: Jump leads wrong way round
  1. Exclamation Jump leads wrong way round
    Hi can any one help, like a numpty i left the interior light on over night in my 1.9 TD T4. ..... I tried to jump start it off a booster pack but it was flat. Then i tried to jump start it off my car, with jump leads but connected the leads negative to positive by mistake. now it wont turn over at all...! Now when i turn the key all that happens is the dash lights come on and a little click, followed by a buzzz sound which seems to be coming from the dash area. Have i fried the ECU..?
  2. Re: Jump leads wrong way round
    Chester-le-Street, United Kingdom
    i don't think so,you may be lucky.it may just be the relay.
    first time i was up a ladder i was down a well
    4th cog,--two to go
  3. Re: Jump leads wrong way round
    hi stewy, you say it might be the relay... which relay and how do i tell if it is ...?
  4. Re: Jump leads wrong way round
    Quote Originally Posted by GuitarBob View Post
    bob,
    i'm only guessing,from what i've read on here.
    i honestly can't tell you exactly where it is,but if you type "buzzing relay"
    or similar into the forum search,it's well discussed.
    i would say it was the starter relay,but only guessing.
    i wouldn't have thought the ecu would put the dash lamps on if it was fried.
    only guessing,but try the search for the buzzing relay.
    regards,
    stewy.
    4th cog,--two to go
  5. Re: Jump leads wrong way round
    I would check all fuses as well as the specific 'buzzing relay' as you never know what else could have blown. Good luck!
  6. Re: Jump leads wrong way round
    Thanks Stewy , i'll have a read through.. Thinking back im not sure that the digital part (the bit that shows the mileage) was showing anything, it may have only been the little Red & Yellow bulbs that where lit, I'll have to check that again in the morning. and the buzzin happened after i turned the key back off, i dont know if that sheads any more light on it...?
    Cheers Jay, I'll check those too..
  7. Re: Jump leads wrong way round
    What a result...! Having spoken to several mechanics and searched the interweb, i was told " Ah sounds like you've fried the ECU" or " That will be the starter relay." and "you probably blown a fuse" and even " You've probably killed the starter motor" Argghhh..! So i was expecting a rather hefty repair bill one way or another.... Then i bumped into an old mate of mine,who works on fork lift trucks, and he said " I reckon you've done the battery" So i thought id get a new one as that sounded like the best place to start.... BINGO..!!!!
    So if any body else is unlucky (Stupid) enough to do what i did , It's worth trying a new battery first. £45 Job done..!
  1. Please Help Damaged Ecu Due To Jump Leads Spike? Golf Mk4
    By Mystercd in forum Golf MK4 - 1999 - 2004
    Last Post: 06-11-2008, 08:53 PM
  2. Jump Starting
    By hagis in forum Archive posts
    Last Post: 18-01-2008, 07:43 PM
  3. R8 round the Ring.
    By prolfe in forum Chat - Anything with wheels
    Last Post: 06-09-2007, 08:22 PM
  4. Anyone want to do a Parachute jump?
    By skymaster in forum Chat - Completely Off Topic
    Last Post: 25-03-2007, 10:03 PM
  5. AUDI BREAKS SKI JUMP RECORD AGAIN FOR NEW TV ADVERT
    Last Post: 15-03-2005, 09:00 PM
