Thread: key code fault 1995 a4
Results 1 to 8 of 8
  1. key code fault 1995 a4
    coventry
    Hi all can anyone help when i go to start my 1995 A4 1.8 20v the key code light comes on and i cant start car so i have to keep taking key out and try a few times untill it goes off.The key has no fob on it can anyone help.
    many thanks
    joe
  2. Re: key code fault 1995 a4
    I have the same problem.....
    Is there any way to ''turn off'' key code?
  3. Re: key code fault 1995 a4
    holygrail720 Guest
    same here..have to keep taking the key in and out to get it to work...i only have one key and would like to get another to see if its the transponder but i cant find anyone who can do it. the key i have dosnt have remote locking just a light.inside it says pa6 gf30...anyone have a solution for this?
  4. Re: key code fault 1995 a4
    Dec 2007
    Suffolk
    Try using you spare keys, if you still have problems then check the reader coil connections.
  5. Re: key code fault 1995 a4
    coventry
    Quote Originally Posted by smokey0123 View Post
    Hi where is reader coil connections? and how do you check it cheers for reply
  6. Re: key code fault 1995 a4
    Dec 2007
    Suffolk
    Quote Originally Posted by joz119 View Post
    The reader coil is around the ignition barrel. Take the plastic off from around the steering column and they should be easy to find (IIRC they sit at the top) There is a known issue with the wires being too short and Audi sell a modified part now. Adjusting the steering whell normally starts all the problems.
  7. Re: key code fault 1995 a4
    coventry
    cheers will check it out
  8. Re: key code fault 1995 a4
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    My car A4 petrol did this occasionally,but if you turn ignition off,wait a second or 2,turn it on and wait for all the ignition lights to go off first and `THEN`start the engine it should start.Sometimes you can `beat` the system before it has had time to read the key code.try taking your time b4 starting.
  1. 1995 A6 heated seats ABK engine code
    By Roadtoad in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 13-09-2008, 03:46 PM
  2. Please Help 1995 80 Windows and Sun Roof fault
    By himtall in forum 80 - 90
    Last Post: 27-08-2008, 11:09 PM
  3. Audi 1.8t Sport 1995 (AEB engine code) sunroof
    By hilton.jones in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-04-2008, 11:30 PM
  4. Fault with glow plugs on 1995 diesel vento
    By ManiacMunz in forum Vento - 1994 - 1998
    Last Post: 22-02-2008, 06:22 PM
  5. Replies: 0
    Last Post: 15-01-2008, 01:07 AM
