Thread: 1995 Quattro 2.8 manual
  1. Re: 1995 Quattro 2.8 manual
    Pembrokeshire
    22 Post(s)
    ok, that light is telling you either pads low , brake fluid low or hydraulic pressure low. try starting car, wait till light goes out, then pump brake pedal. the light should come on , then go out again. turn engine off and pump the brake pedal until it goes hard. mine does about 30 pumps, then goes hard. im not sure of the limit but there is another thread on here all about it. i believe less than 20 ? and your bomb has had it. thats the sphere that holds the pressure in the hydraulics, and looks like a hand grenade somewhere below you abs pump.
  2. Re: 1995 Quattro 2.8 manual
    megavolt Guest
    Hi Zollaf,
    I did some checking around, but no improvement. There was no problem with 'the bomb' but I have noticed the following scenario:
    1. When the warning appears it is accompanied by three bleeps. This will usually start within about 1 minute of driving off in the morning.
    2. This will be repeated at frequent, irregular intervals for the next 10 to 15 minutes. It all then disappears until the evening or following morning when everything has cooled down again.
    Hmmmmm??
    Kind regards,
    Megavolt
  1. Please Help audi a4 2.6 v6 quattro 1995
    By unitedstomp in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-08-2008, 07:31 PM
  2. Erratic idle A4 Quattro - 1995- 2.6
    By JDA in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-02-2008, 07:49 PM
  3. 1995 A4 Quattro - Handbrake cables
    Last Post: 20-01-2008, 07:58 PM
  4. 1995 A4 Quattro - Heated rear screen switch
    Last Post: 14-01-2008, 07:49 AM
  5. 1995 Cabriolet Manual
    By Timja in forum 80 - 90
    Last Post: 30-08-2007, 03:01 PM
