Thread: Heating/Air Con Fan Squeaking!
  1. Unhappy Heating/Air Con Fan Squeaking!
    My Oct 2006 2.0 TDi has developed an incredibly irritating squeak-squeak-squeak noise from the heating fan inside the car! It high pitch but the squeak happens at a rate of 3 or 4 times a second.
    Having experimented over the last few days the squeak is linked to the fan being on (it stops as soon as you turn the fan off) and the movement of the car. A bumpy road makes the squeak more pronounced as does the weather ie on a frosty morning the noise is slightly different.
    My guess is rather that the fan motor itself, its something about how the unit is mounted. If its on bushes (of some kind) then those are rubbing OR a cable or similar is rubbing against the unit.
    Can someone point me at where the unit is in the dashboard/centre console area and, more importantly, am I going to bu**er anything up by giving it a quick spray with WD40?!
    Any other suggestions very gratefully received.
    Thank you
    David
  2. Re: Heating/Air Con Fan Squeaking!
    South Wales
    I have the same problem...
    it is like something is loose and slightly hitting the fan..
    it only happens now and again.. did take it to the dealer to check, but all they did on the job sheet I signed was" fix glove box rattle" which is a common fault..but the problem is still there..
    on my previous car had the same annoying problem..
    just turn the radio up higher...
    BMW X1 Lowered with 20" black rims & Bluemotion Passat estate Audi A3 Cab S- line 1.6 D
    VW Sharan highline xenon leds cornering lights 17" Jarama alloys 170 2.0 D DSG
    BMW s1000RR track bike KTM RC8 road bike
    Two... sorry now.... Three Miniature Dachshunds.... Have you seen my weiner
  1. Squeaking when turning right
    By rob160 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-08-2008, 01:14 AM
  2. Squeaking!
    By TDiBoraSam in forum Bora - 1998 - 2005
    Last Post: 28-02-2008, 01:53 PM
  3. Squeaking Noise??
    By take_this_oath in forum Audi A3 - Archive Topics
    Last Post: 21-02-2008, 09:52 AM
  4. Brakes Squeaking!
    By tone70 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-06-2007, 05:30 PM
  5. squeaking and ticking
    By rockbadger69 in forum 80 - 90
    Last Post: 17-02-2007, 03:03 PM
