Thread: 80 cabriolet
  1. Lightbulb 80 cabriolet
    Helpm ,y front nearside (UK) sidelight has expired and I cannot get in to replace the bulb. Can anyone advise me please? It's emabaeaasing as I used to rebuild Land Rover engines as a hobby and I cannot get into my Audi sidelights and I feel old and ashamed of myself
  2. Re: 80 cabriolet
    Pembrokeshire
    22 Post(s)
    you obviously have short fat finger syndrome. it is just about possible to get to the n/s bulb holder to give it a twist and pull it out. your probably better off getting someone with long thin fingers to do it for you. failing that just pop the whole headlight unit out, then its really easy. just wait till your o/s bulb needs replacing..
  3. Re: 80 cabriolet
    You're right, I do have short fat fingers and can just about reach the buld holder but not enough to turn it. I think headlight unit out is the answer.
    Thanks for the repsponse and advice.
  4. Re: 80 cabriolet
    Pembrokeshire
    22 Post(s)
    no worries. it would seem that most blokes into cars also suffer from this syndrome. the ones with long thin fingers all seem to be computer geeks or bankers.good luck with that bulb.
  5. Re: 80 cabriolet
    Sep 2007
    Should be able to reach if not open bonnet undo the star headed screw on the lower trim beneath headlamp then pop it out of the plastic clip round by the wing under indicator then undo the 4 screws two below headlamp and two above and then the headlamp just comes out plenty room for your FAT fingers LOL
    cheers Raj
    S2 Coupe
    S2 Avant
    V6 coupe
    80 Tdi
    80 Tdi Avant
  1. Cabriolet
    By Russ146 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 04-09-2008, 05:17 PM
  2. A3 s-line cabriolet
    By matmaxedout in forum Audi A3 - Archive Topics
    Last Post: 16-07-2008, 07:00 PM
  3. A6 Cabriolet
    By rudivisser in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 20-11-2007, 10:30 PM
  4. Which A4 Cabriolet?
    By zeratul in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-06-2007, 12:55 AM
  5. A4 cabriolet
    By ribster in forum Audi A4 - Archive Topics
    Last Post: 04-01-2007, 09:02 PM
