Thread: Audi A4 TDI Gearbox Codes
  1. Audi A4 TDI Gearbox Codes
    New to this site/ posting so bear with me!
    I have a 1997 R plate A4 Avant 19 tdi with 95k on the clock. Recently it has started crunching 3rd so think the synchro has gone and also 1st gear selection has started playing up.
    Prior to this for about 2 months the clutch has been judering, suspect the springs in the plate? I meant to do it before now but........
    Anyway, I contacted the Audi dealer with Chassis number and reg and he said the gearbox code was DHL.
    Local breaker has a DHU (from memory)
    Does anyone know if the gearboxes are the same externaly/ clutch spline and a direct replacement even if the code is different?
    Does anyone know who can tell me the ratio's go with what gearbox code?
    Any advice or previous experience of the code saga would be appreciated as it's a bit of a minefield!
  2. Re: Audi A4 TDI Gearbox Codes
    Send your e-mail address and i will send you what you need to know.The DHU box is used in the 2,4 and the 2,6 A4.
  3. Re: Audi A4 TDI Gearbox Codes
    Cheers kenny
    I have recieved some information to my email from the forum.
    I have sent my email address to the administrators to pass on as i cannot send pm's yet.
    Calum
  1. Fault Codes On Audi A4
    By villian210 in forum VCDS - General Questions
    Last Post: 13-08-2008, 09:27 PM
  2. Audi Codes Always Cost!!
    By davo79 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 01-07-2008, 12:39 AM
  3. transporter gearbox codes
    By nicholas_newton in forum The Commercial Range
    Last Post: 11-09-2007, 03:35 PM
  4. Audi A6 1.8T VAG Codes
    By iainbrads in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-02-2007, 01:34 PM
