Thread: Headlight adjustments
  1. Headlight adjustments
    Aug 2007
    What are the rules regarding headlight adjustments? I know it's checked on MOTs, but what specifically are they looking for.
    I accidentally adjusted one of mine when I was changing the bulb last weekend but I've a suspicion that they're both out of alignment are might be too high.
  2. Re: Headlight adjustments
    London
    Headlamp Alignment Testing Criteria
    The most common type of headlamps fitted to vehicles are those known as European type headlamps which are checked for aim on the dip beam.
    These headlamps have an asymmetric dipped beam pattern with a distinctive horizontal cut-off on the right, and a 15 degree wedge of light above the horizontal (the 'Kick up') towards the left.
    Any of the following points will result in the vehicle being refused a certificate:
    • The beam pattern blurred and does not show a distinctive cut-off point.
    • The beam 'kick-up' is to the offside, i.e. The headlamp dips to the right.
    • The image break point is not between the vertical -2.0% line (blue vertical line) and the vertical 0% line (black vertical line).
    • Headlamp centres not more than 850mm above the ground. The beam horizontal cut-off line (pitch) is not between -0.5% and -2% line (red lines).
    OR
    • Headlamp centres more than 850mm above the ground. The beam horizontal cut-off line (pitch) is not between -1.25% and -2.75% line (green lines).
    NOTE: There will be no opportunity to adjust headlamp alignment during the test. Levelling devices should be set for unladen condition, normally located on vehicle dash.
    Example of computer screen showing the Light Beam Test readings
  3. Re: Headlight adjustments
    Aug 2008
    Hamilton
    I too would like to check my headlight adjustment, as I've just fitted a set of HIDs to my A4. Is there any kind of "ball park" test that you can carry out yourself, ie, park the car 'x' distance from a wall, then adjust the beam pattern to 'y' height on the wall?
    Or is that just too simple...................
    Current - Audi A4 Avant 2.0 Tdi Quattro 170 Sline SE (2007)
    Gone but not forgotten - Audi A4 Avant Tdi Sport (2004)
    Gone but not forgotten - Audi A4 Tdi Quattro (1997)
  4. Re: Headlight adjustments
    Mar 2008
    High Wycombe
    Well, if you park 20m away from the wall, then you can work out how much the lights should drop:
    Using the rule of 0.5% to 2%, the image break point should be between 100 and 400mm below the centreline of the headlights. (assuming that % slope means drop as percentage of distance - I usually work in degrees)
    This only becomes too simple in that finding a dead flat piece of ground is virtually impossible: The ground needs to be horizontal between the front of the car and he wall (otherwise you're not measuring upto the centreline of the headlights well enough), and the ground needs to be flat between the front and rear wheels (if the front wheels are half an inch higher than the rear ones, then that's 0.5% slope).
    I'm a civil engineer, and do quite a bit of measuring of relative heights. You could use a spirit level with a laser beam attached to measure the relative heights of the front and rear wheels, and then use the laser to project the headlight centreline to the wall, and work out the correct drop from those measurements.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  5. Re: Headlight adjustments
    Aug 2008
    Hamilton
    Quote Originally Posted by NickPicks View Post
    Thanks for that ......................perhaps I'll just go ask a local garage to align them..........
  6. Re: Headlight adjustments
    Aug 2007
    I'm more confused than I was before (though thanks for posting the details!). I think mine are too high so I've used the headlight adjustment on the dashboard for now.
  1. Headlight!
    By vw754 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-03-2008, 11:17 AM
  2. Bose Symphony Adjustments
    By acoccoluto in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-12-2007, 10:11 AM
  3. Headlight Help
    By 01V5 in forum Bora - 1998 - 2005
    Last Post: 16-09-2007, 01:17 PM
  4. Front Bumper Adjustments
    By Mackenzie_Mark in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-06-2007, 08:47 PM
