Thread: A6 4.2 quattro
Results 1 to 9 of 9
  1. A6 4.2 quattro
    Feb 2007
    NI, UK
    Hi, guys, I just bought a A6 4.2 2000, it is being repaired due to a light frontal damage. The brake pedal drops to the floor, there isn't any fluid leaking (that I can see), just wandering if it was a fault with these?
    Also the gearbox seems to playing up, will not drive in reverse (auto), common fault?
    The engine sounds awesome , can't wait to get it back on the road.
    Regards
    Steve
    Nov 2006
    Swampyland, UK
    Quote Originally Posted by brown934 View Post
    For the brake issues, have a look at these two recent threads. If you get no joy, get back to us with a little more info on the detail of your diagnosis:
    https://www.vwaudiforum.co.uk/forum/s...ad.php?p=18371
    https://www.vwaudiforum.co.uk/forum/s...ead.php?t=3877
    Ohh, sounds bad, but not my area, so I'll leave that to others. I presume it is the standard Tiptronic slush box, and not the multitronic?
    Oh yus - that I can vouch for!
    May 2006
    Exmouth, Devon, UK. Drives Bonkers Fabia Diesel. Has full VCDS
    Brakes sounds like there's air in the system. I would suggest a full flush through, refill and re-bleeding.
    Not sure on the box. Could be just electronic. What kind of accident was it? Nothing that could have affected the box?
    Jason - Rather mad Skoda Fabia driver.... Odd whiff of diesel coming from him.
    260bhp Skoda Fabia TDI Dyno Run
    http://www.youtube.com/watch?v=9BvjJjL7Z50
    315bhp Skoda Fabia TDI Dyno Run (2013)
    http://www.youtube.com/watch?v=TOE4nbT5NGY
    Feb 2007
    NI, UK
    Guys, thanks you your help.
    It's a normal triptronic box.
    I'm not sure about the accident. I was told is was a low speed accident in a field at a car boot sale. I was told that the car ended up in a ditch & damaged a brake line. I check all the lines and no breakage or leaks. It light damage to the off side front. near side doors. I was told that the oil cooler for the gearbox was damaged,I couldn't see any damage.
    Nov 2006
    Swampyland, UK
    Quote Originally Posted by devonutopia View Post
    Could also be a kaput servo or master cylinder too, or the ABS modulator! Even pumping the pedal to see if it rises isn't a definative test for air.
    Rgds
  6. Anyone know S6 maximum wheel clearance?
    I'm trying to find out if a 19 x 9 et 35 wheel wraped in a 265/35-19 will fit, with no rubbing, my 03' S6....Anyone know?
    Austin Texas
    I don't think the seller is not telling the truth!
    Take it to someone who can properly take care of your car...Brakes are rather important and so is the gearbox I might add.
    my $0.02
    Shawn Olsen Austin TX ACNA#1616
    //95 S6 RS2 // 02 A6 4.2 // 04 S4
    The brake fault you describe sounds like the seals in the master cylinder have gone. But are you sure there's no fluid leaking anywhere? After a crash.....
    Dunedin, New Zealand
    I would also suggest a full oil and filter change on the transmission - costly, but if the oil cooler was damaged you never know what little bits could be floating in there......
    Best make sure you do the oil change after you sort the transmission fault though - you would hate to pour all that expensive new oil away if you have to crack open the trans to fix the fault!!
  1. 1.8T or 1.8T Quattro
    By nickpw27 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-12-2007, 01:17 AM
  2. A3 quattro or not????
    By spadey in forum Audi A3 - Archive Topics
    Last Post: 11-04-2007, 07:53 PM
  3. A4 Quattro
    By ianmcneill in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-03-2007, 02:07 AM
  4. 90 Quattro V8 in a 89 80Q?
    By AdirondackQ in forum 80 - 90
    Last Post: 31-01-2007, 09:43 PM
  5. A3 - Quattro or DSG
    By SCS in forum Audi A3 - Archive Topics
    Last Post: 15-06-2006, 10:34 PM
