Thread: Rear parking sensors broken?
Results 1 to 10 of 11
  1. Rear parking sensors broken?
    Aug 2008
    Redcar, Cleveland
    got a 99 2.5 v6 quat avant auto.
    when engaging reverse i get a long constant sound beep maybe 3 seconds long.
    i guess this means the sensors have a problem?
    when i recently parallel parked i got no noise from teh sensors to tell me im closing in on the parked car behind me.
    is there a short term way of disabling th noise? ie pulling a certain fuse?
    is it easy to change the sensors.? i assume the little lip on teh bottom of th back bumper is a addition over the standard bumpers and may come off the main bumper?
    cheers
    ps noticed in service history a couple of sensors were changed early this year...maybe the other 2 have failed?
  2. Re: Rear parking sensors broken?
    London
    I ahve very similiar issues. Sometimes a long continuous tone (which does not stop!), sometimes a continuous tone for a few seconds which then repeats itself and sometimes it just works fine!!
    I am suer it is a sensor issue the question is how best to identify which one or ones are faulty. I don't know if the long bleeps give a clue but will try and do some research.
    I have an early 2002 with the separate rear bumper section which holds the sensors, much like yours most likely. They just clip into place and can be pushed out from behind without removing the bumper or that valance I think.
    I noticed when I bought the car one of the sensors has some surface damage on it which could be causing the problem.
    I will let you know how I get on.
  3. Re: Rear parking sensors broken?
    Southern County Softy
    20 Post(s)
    Vagcom will tell you which sensor is faulty.
    A4 2.5 tdi QS (mapped)
  4. Re: Rear parking sensors broken?
    London
    Ah, don't have it unfortunately. I use Eshrules handy hand held Pro Checker for fault codes and a few other bits but I don't think it will read sensor info.
    Maybe it's time to invest in VAGCOM.
  5. Re: Rear parking sensors broken?
    20 Post(s)
    Or find someone close by to do a scan for you.
  6. Re: Rear parking sensors broken?
    Jul 2007
    Cheshire, or my A6
    Hence the VAG-COM User Locations thread in the VAG-COM section.
    Paul
  7. Re: Rear parking sensors broken?
    London
    Sure I know about the help out there which is a great benefit I just figure it's about time I got it for myself anyway
  8. Re: Rear parking sensors broken?
    Jul 2007
    Cheshire, or my A6
    Quote Originally Posted by audipersempre View Post
    So round two with Eshrules then?
    Paul
  9. Re: Rear parking sensors broken?
    London
    Bit worried about that actually after the ask Uncle Christopher thread!!!
  10. Re: Rear parking sensors broken?
    Jul 2007
    Cheshire, or my A6
    I'm sure you know what I meant.
    Paul
  1. Rear Parking Sensors
    By Jasperse in forum Jetta MK3 - 2005 - 2013
    Last Post: 26-08-2008, 04:41 PM
  2. Rear parking sensors - what's going on?
    By browellm in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 12-06-2008, 01:29 PM
  3. Very quiet rear parking sensors - adjustment?
    By wattsn in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-05-2008, 12:27 AM
  4. Fitting rear Parking Sensors?
    By zeratul in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-03-2008, 08:44 PM
  5. Another rear parking sensors
    By Rampage in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-09-2007, 09:32 PM
