Thread: 1996 a4 tdi loss of power. help please
Results 11 to 20 of 24
  1. #11
    Feb 2007
    Sheffield
    in my manual, the valve mentioned is behind the right headlight, accessed by removing the inlet duct. Sounds like it has a vacuum pipes and a wired plug. Hope this helps!
    Feb 2007
    thanks. i'll have a look
    Feb 2007
    Hi, Ive had this fault on quite a few pd engines. Try the map sensor in the silver inlet pipe,there about £30. Does it show a boost fault on diagnostics. The ones ive done have been around 90k miles,good luck.
    Feb 2007
    can you explain how to tell if there is a boost fault. i'm a bit new to all this. thanks
    Feb 2007
    Hi, get it checked on a code reader. These cars do strange things when other sensors go down making you change parts for nothing. Check the fault memory then clear it, road test it so that it does the fault, then recheck the fault memory, may say boost limit reached or adaption fault.
    Feb 2007
    i've done that and the code 00575 inlet manifold pressure is the only code that shows
    Feb 2007
    Hi, sounds like the map sensor. Have you any breakers near you to try one. Takes 2 seconds to change with screwdrver. Typical as i see loads today at breakers yard.
    Feb 2007
    where exactly is the MAP sensor as i've had trouble identifying it?
    Feb 2007
    Hi, open the bonnet. Take off the engine cover 3x 10mm nuts.look where the inlet pipe goes along the back of the engine and theres the map sensor,its held in by 2 screws and has a plug connector to it.cheers.
    Feb 2007
    thanks. i'll have a look at that in the morning.
  1. loss of power
    By sacko17 in forum Touran - Sharan - Caravelle
    Last Post: 13-11-2007, 01:54 PM
  2. Power loss
    By Eugheugh in forum Passat - Archive Topics
    Last Post: 27-03-2007, 06:22 AM
  3. A4 1996 1.9 tdi power loss
    By Robs in forum Archive posts
    Last Post: 30-01-2007, 08:24 PM
  4. Power problems with 1996 A4 110hp TDI AFN
    By ollied1981 in forum Archive posts
    Last Post: 28-11-2006, 12:52 PM
  5. loss of power
    By Lofty in forum 80 - 90
    Last Post: 22-07-2006, 06:28 PM
