Thread: Help with B5 Passat rough idle please????
  1. Exclamation Help with B5 Passat rough idle please????
    Hi Guys I am a newbie, I'm having an ongoing problem with my Passat T/98 1.8 20V SE, APT engine. It has a problem with idling when warm, normally only after a long journey.
    After a long journey back in July, the car started having problems with rough idle. After investigating I noticed I had melted two breather pipes which lead to the throttle body. I replaced these and it altered nothing, I changed the MAF filter, but nothing, I cleaned the TB but nothing again. I have had it on VAG COM by a VW specialist but they only found some old faults which were cleared. This is now becoming very frustrating . I am going to replace the Coolant temp sender, but I can't find where to buy them with out going to VW dealer, any suggestions?
    Also another question is..... there is a part on the engine which is broken, but I don't know what its called or where to get it. It is a little plastic arm located behind a flat plastic cover parrallel with the throttle body at the front of the engine. I think it is part of the rocker cover and has something to do with the air flow? I am sure this is playing a huge part in the problem with the idle. I thought it would be a common fault but can't find anything on here about this part.
    Sorry for the long post, would be really grateful if someone knows the answers and could help me out??
    Cheers Lee
  2. Re: Help with B5 Passat rough idle please????
    Mar 2008
    High Wycombe
    The broken arm sounds a bit dodgy.
    Any chance of a photo to help us identify the part?
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  3. Re: Help with B5 Passat rough idle please????
    i will add some tomorrow
  1. rough idle
    By lodak in forum Vento - 1994 - 1998
    Last Post: 19-11-2008, 02:02 PM
  2. Question A4 2.6 rough idle/rough at high rpm
    By teccyjim in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-09-2008, 07:22 PM
  3. rough idle
    By chimp in forum Golf MK4 - 1999 - 2004
    Last Post: 31-07-2008, 07:47 AM
  4. A6 rough idle
    By evandar in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-03-2008, 06:30 PM
  5. 1997 Passat 1.8 non turbo rough idle fault
    By JHT in forum Passat - Archive Topics
    Last Post: 18-01-2007, 05:36 PM
