Thread: s/hand convenience control module's
Results 1 to 10 of 10
  1. s/hand convenience control module's
    Suspect my convenience control module is playing up, the current module does look like it's been wet in the past so I've managed to get a s/hand one from a breakers....will it have to programmed to suit the car if so how much?
    Mark
  2. Re: s/hand convenience control module's
    Did this to mine,it will fit the car but the keyfob will not work you will have to lock the doors the old fashioned way with the key or pay to have it reprogrammed to fit the key
    Ed
  3. Re: s/hand convenience control module's
    Dec 2006
    Stoke/Congleton
    If you have 2 keys you can program them yourself.
    It is in the manual of some cars but emitted on newer cars.
    I cant remember exactly so you may have to change instructions to work.
    1 key in the ignition (on).
    Drivers window down.
    Get out of the car and lock the door with the 2nd key and then press the key fob of key to be programmed and it should acknowledge with a flash or beep.
    And then quickly after press the other key fob.
  4. Re: s/hand convenience control module's
    Dec 2006
    Stoke/Congleton
    Also make shore the module is same part number as there are different ones.
  5. Re: s/hand convenience control module's
    Cheers guys, just found out tonight that all my problems are actually down to broken wiring in the loom just as it go's of into the c/m, all the factory soldered joints have broke or nearly broke
    Going to start to fix them over the weekend, very poor design on VW part.
  6. Re: s/hand convenience control module's
    Dec 2006
    Stoke/Congleton
    Its the water that does it.
    Now how the water gets there is a very hot topic.
  7. Re: s/hand convenience control module's
    Cheers Steve, I've sorted out the water outlets under the bonnets and just to be sure I've drilled a small hole in the passenger footwell...drastic I know but I don't want this hassle again.
  8. Re: s/hand convenience control module's
    Just doing mine now,the water was coming in through the n/s/r passenger door panel,took door card off and the seal around the metal plate had gone around the bottom,took old seal of and resealed it with dum dum.Take the plastic trim off f/n/s passenger footwell,behind this is a bank of block connectors all mine are trashed,i am chucking them all in the bin and resoldering them tomorrow.God i miss me old Omega sniff ((
    Ed
  9. Re: s/hand convenience control module's
    **** me Ed, thats bad news m8, this is my first veedub and i'm not happy at all, i thought they were bullet proof
  10. Re: s/hand convenience control module's
    Oct 2005
    sligo ireland
    i have a similar prob the windows doors and roof have all stopped working
    checked the ccm bone dry and all multi plugs in footwell dry as well
    replace fuses 30 and 38 still no luck
    been told on another forum could be 30 amp fuse behind relay panel below steering wheel or a relay itself
    paul
  1. Vag com and convenience module
    By dysdera in forum VCDS - General Questions
    Last Post: 23-06-2009, 04:03 PM
  2. Convenience Module
    By Marc97 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-05-2008, 01:59 AM
  3. Replies: 7
    Last Post: 07-04-2008, 09:00 PM
  4. Location of Convenience control on Alembra
    By bravo6 in forum Touran - Sharan - Caravelle
    Last Post: 16-02-2008, 10:53 PM
  5. Convenience system central control
    By ukheman in forum Golf MK5 - 2004 - 2009
    Last Post: 27-12-2007, 06:37 PM
