Thread: s/hand convenience control module's
Results 1 to 10 of 10
  1. s/hand convenience control module's
    Suspect my convenience control module is playing up, the current module does look like it's been wet in the past so I've managed to get a s/hand one from a breakers....will it have to programmed to suit the car if so how much?
    Mark
  2. Re: s/hand convenience control module's
    Did this to mine,it will fit the car but the keyfob will not work you will have to lock the doors the old fashioned way with the key or pay to have it reprogrammed to fit the key
    Ed
  3. Re: s/hand convenience control module's
    Dec 2006
    Stoke/Congleton
    If you have 2 keys you can program them yourself.
    It is in the manual of some cars but emitted on newer cars.
    I cant remember exactly so you may have to change instructions to work.
    1 key in the ignition (on).
    Drivers window down.
    Get out of the car and lock the door with the 2nd key and then press the key fob of key to be programmed and it should acknowledge with a flash or beep.
    And then quickly after press the other key fob.
  4. Re: s/hand convenience control module's
    Dec 2006
    Stoke/Congleton
    Also make shore the module is same part number as there are different ones.
  5. Re: s/hand convenience control module's
    Cheers guys, just found out tonight that all my problems are actually down to broken wiring in the loom just as it go's of into the c/m, all the factory soldered joints have broke or nearly broke
    Going to start to fix them over the weekend, very poor design on VW part.
  6. Re: s/hand convenience control module's
    Dec 2006
    Stoke/Congleton
    Its the water that does it.
    Now how the water gets there is a very hot topic.
  1. Vag com and convenience module
    By dysdera in forum VCDS - General Questions
    Last Post: 23-06-2009, 04:03 PM
  2. Convenience Module
    By Marc97 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-05-2008, 01:59 AM
  3. Replies: 7
    Last Post: 07-04-2008, 09:00 PM
  4. Location of Convenience control on Alembra
    By bravo6 in forum Touran - Sharan - Caravelle
    Last Post: 16-02-2008, 10:53 PM
  5. Convenience system central control
    By ukheman in forum Golf MK5 - 2004 - 2009
    Last Post: 27-12-2007, 06:37 PM
