Thread: VW Sharan pollen filter
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. Re: VW Sharan pollen filter
    May 2008
    wirral
    i also have a 03 sharan iv done mine twice now the hardest thing is sliding it out i never touched my wipers at all took about 20 mins if you have a look on the ford galaxy owners forum there is a piece in the q&a section done by seatkid with very good pictures as well trust me when you have seen these pictures & the way it is explained the replacement is not hard at all check it out...hope this helps...
  2. Re: VW Sharan pollen filter
    Mine's a 97 normal UK Sharan TDI and I only needed to remove the 3 foot wide shelf thing that is held in by three screws to access the pollen filter. I did not need to remove any wipers or linkages, but have a dim recollection of having to park the wipers in the upright position. Of course I removed the battery connection afterwards as I didn't want the mechanism to park itself with my fingers in there.
    Sure it took an hour or so of fiddling to get the shelf out and figure how to remove the front retaining bit of the filter holder, but after that it was not rocket science. In the end I didn't see exactly how the front retaining bit did come off, and remarkably it went back on easily enough - just seemed to click into place.
    That's an odd thing I have found with my VWs - if I can't figure how something is fastened on, it will usually come off by pulling or prising...
    Hope this helps. OD
  1. pollen filter
    By beetleboy in forum Beetle 2000-
    Last Post: 06-02-2010, 06:30 PM
  2. POLLEN FILTER ON VW SHARAN 2003 MODEL
    By kimsue in forum Archive posts
    Last Post: 05-02-2008, 11:00 PM
  3. Pollen filter location
    By deebee in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 17-06-2007, 07:34 PM
  4. Pollen Filter
    By tony_anon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-05-2007, 03:21 PM
  5. pollen filter seal
    By southwest in forum Passat - Archive Topics
    Last Post: 04-03-2007, 04:15 PM
