Thread: VW Sharan pollen filter
Results 1 to 10 of 12
  1. VW Sharan pollen filter
    Jan 2005
    Can anyone advise how to replace the pollen filter on my 2003 Sharan. The main dealer service dept quoted "this was designed by a mad man" and suggested not replacing it as it takes as long as a service, lots of things can go wrong and get broken due to trying to access it and if it is not fitted correctly water can enter vehicle and the whole thing has to be done again. If VW dont want to touch it who does !! Another quality and well designed vehicle from VW.... not. Where did they every get a reputation for quality & well designed products ??
    Oct 2005
    I find it strange your dealership turned you away.
    https://www.vwaudiforum.co.uk/forum/showthread.php?t=291
    This may help you but from a little bit of searching it would appear you may have to "first remove the windscreen wiper blades and the protective cover" hence the unwillingness for mechanics to have a go themselves.
    Very labour intensive.
    Jul 2006
    scunthorpe
    have done this on my sharan not recomended unless u like hard work elsawin says that it can be slid out but it shows a lhd car, i ended up taking wiper blades off and all the linkages as well took 2-3 hrs a right pain in the behind
    Feb 2007
    once you have done a few its about 10 mins work but if its your first one you will lose some blood
    Jul 2006
    scunthorpe
    changed filter today 1 hr getting better!!
  6. Re: VW Sharan pollen filter
    Jan 2009
    Quote Originally Posted by andy e View Post
    Hi Andy_e
    How did you manage to take the windshield wipers off ?
    I couldn't take the windshield wiper arms off even after taking the bolts off and was afraid I would break it if I pulled too hard.
    I appreciate your advice.
    Tks, John
  7. Re: VW Sharan pollen filter
    Aug 2007
    Quote Originally Posted by integra_john View Post
    Quoted for truth, it can be done without removing wiper blade IIRC, but it was a PIA and the hands!!
    Good luck, fiddly, not difficult really, just give yourself plenty of tme and try to remain calm
  8. Re: VW Sharan pollen filter
    Jul 2006
    scunthorpe
    Quote Originally Posted by DonPepe View Post
    Hi Andy_e
    Tks, John
    put the nuts back on spindle but not quite to the arms leaving a couple of threads showing, lift the wiper blade arm to the vertical position, then get a soft faced hammer and tap the arm on the spindle at the same time pulling the arm up it will come loose
  9. Re: VW Sharan pollen filter
    Jan 2009
    My goodness, the windshield wipers are fixed by pressure ?
    Great tip ! I'll try as soon as I can find a whole day or at least half a day.
    Regards
    John
  10. Re: VW Sharan pollen filter
    Jul 2006
    scunthorpe
    they are on splines, but that is the easiest way to get them off without skinning knuckles/swearing/breaking windscreen and all the other malodies that come with changing the bl@~Dy pollen filter,have fun
  1. pollen filter
    By beetleboy in forum Beetle 2000-
    Last Post: 06-02-2010, 06:30 PM
  2. POLLEN FILTER ON VW SHARAN 2003 MODEL
    By kimsue in forum Archive posts
    Last Post: 05-02-2008, 11:00 PM
  3. Pollen filter location
    By deebee in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 17-06-2007, 07:34 PM
  4. Pollen Filter
    By tony_anon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-05-2007, 03:21 PM
  5. pollen filter seal
    By southwest in forum Passat - Archive Topics
    Last Post: 04-03-2007, 04:15 PM
