Thread: Buzzing from engine on cold startup - 1.8T
  1. Buzzing from engine on cold startup - 1.8T
    Hi all,
    I've got a B6 1.8T and just recently (Maybe due to the cold weather) I have heard a buzzing noise from the engine bay. It happens as the autochoke takes the revs over 1,000rpm and then dissapears after a minute when the revs drop to idle speed. When driving around normally, the noise cannot be heard.
    I haven't lifted the bonnet to check it out properly but I can hear it at the same audible level whether I'm stood at the drivers side or the passenger side.
    Anyone care a stab in the dark ?
    Richie.
    Nov 2006
    Swampyland, UK
    Hmm - it could be a secondary air injection pump - used to help the cat heat up quicker?
    Where can of these be found ?
    Nov 2006
    Swampyland, UK
    Dunno exactly, but it could be tucked up inside the front wing, between the outer and inner wing.
    If the noise is only heard on cold starts, and only lasts for about a minute, then that is perfectly normal operation. It's all to do with emissions, and getting the catalytic converters up to operating temperature ASAP. You shouldn't hear it on a warm start.
    Rgds
  1. MkIV Golf - engine runs cold
    By jcp-123 in forum Golf MK4 - 1999 - 2004
    Last Post: 14-01-2017, 09:14 PM
  2. Passat TDI 130 over revs on startup
    By chrispclover in forum Passat - Archive Topics
    Last Post: 29-04-2007, 12:10 AM
  3. 1999 VW Cold Start Engine Problem
    By cmarkopoulos in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 02-04-2007, 10:11 AM
