Thread: How do I replace rear Bushes A3
Results 1 to 10 of 10
  1. How do I replace rear Bushes A3
    Sep 2008
    Have been having problems from a clunking noise at rear of car. have replaced top mounting at suspension but no better. Am now about to replace the rear axle bushes (have purchased new audi ones) but cant seem to find a guide as to how to take the old ones out, have read somewhere that the bush needs hammered out and then a metal slieve removed before fitting the new bush - any advice gratefully received.
    William
  2. Re: How do I replace rear Bushes A3
    Sep 2008
    Dundee
    on my a4 i needed a special tool for the job, i would imagine it would be the same story for your car. not a big job with the tool
  3. Re: How do I replace rear Bushes A3
    Aug 2008
  4. Re: How do I replace rear Bushes A3
    Sep 2008
    Dundee
    my local friendly garage gave me shot of the tool. how lucky is that?
  5. Re: How do I replace rear Bushes A3
    Sep 2008
    I was hoping for some advice on what I need to remove - will the old bush come out complete, do i drill it out and is there a separate metal sleeve that need removed. I have an improvised tool that should get the new one in
  6. Re: How do I replace rear Bushes A3
    Sep 2008
    Dundee
    i think they would be a nighrmare to remove without the tool. have you to see if they do need replaced?
  7. Re: How do I replace rear Bushes A3
    Sep 2008
    Yes they do need done - did you use the tool to remove the old one?
  8. Re: How do I replace rear Bushes A3
    london/ UK
    Quote Originally Posted by wilsby View Post
    You just need a big screwdriver to lever/rip the inner bush out off the housing, then you hack off the sleeve thats left on the rear axle...Grease well the new bush and the axle then proceed with fitting the bush. Mark the corect position of the bush on the axle as its very important. Keep it true and it will go in. Its a very frustrating job if you never done it before and dont have the right tools. I have done a few and i never look forward to do more...By the way, i dont use fancy tools, just good old forged G-clamps, steel washers, few blocks of wood and a dead blow hammer...
  9. Re: How do I replace rear Bushes A3
    Sep 2008
    Thanks for this helpful response - is the sleeve that left behind metal or rubber. Its just that I have read you should remove the bush and the a thin steel sleeve. Don't want to remove something that should still be left in the axle.
    Regards
    Wilsby
  10. Re: How do I replace rear Bushes A3
    Sep 2008
    Thanks to adamss24 - I did the job at the weekend. Took a while to get the old bushes out and I constructed a tool with two pieces of metal pipe (70mm) and two flat steel plates with a long bolt up the centre to pull it all together, worked well and only cost about £5.60 from a local steelworks.
    Now drives much better.
  1. Please Help Rear Axle Bushes!
    By sambojoneo in forum Golf MK4 - 1999 - 2004
    Last Post: 11-06-2008, 12:11 PM
  2. rear bushes
    By vwray in forum Golf MK4 - 1999 - 2004
    Last Post: 25-04-2008, 06:44 PM
  3. rear suspension bushes
    By IANTDI in forum Golf MK4 - 1999 - 2004
    Last Post: 18-10-2007, 02:50 PM
  4. Vw Bora Rear Bushes
    By loz683 in forum Bora - 1998 - 2005
    Last Post: 10-07-2007, 12:39 PM
  5. rear bushes
    By rickgti in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 29-03-2007, 01:31 PM
