Thread: Snapped Window Cables
Results 1 to 10 of 12
  1. Snapped Window Cables
    Sep 2007
    Glasgow
    After a bit of door disassembly, I eventually found out why my driver side electric window wouldn't work - snapped cable. Worse again, the snapped cable had chewed up the pulley. To compound things, the cable runs are all gunged up.
    Anyone know how much it costs for a new set of cables, cable runs and pulley assembly. Looks like bike brake cables to me (pennies), but I suspect I won't get much change out of loads of dosh from a main dealer.
    Any tips???
  2. Cool Re: Snapped Window Cables
    Aug 2007
    just changed the drivers side front. think it was 77 pound from audi. not to bad.. but do have to take the door apart to fit it. grrrrrrrrr
  3. Re: Snapped Window Cables
    Oct 2005
    On my B5.5 Passat the cable/runners/pulleys all come as one part connected to the inner door skin.
    I tried to repair it using bike brake cables but failed miserably.
    I paid just under £50 for the "kit" from VAGParts - A VWAF sponsor.
    The repair is simple if you have the tools and a warm garage.
  4. Re: Snapped Window Cables
    Sep 2007
    Glasgow
    Quote Originally Posted by stevenbennett View Post
    Yep, just about to do this myself tonight. Got the parts from Audi ... £77 for a snapped cable
  5. Re: Snapped Window Cables
    Sep 2007
    Glasgow
    I looked in B&Q - 74p / meter for the cable. Plus some bolts filed to measure and sodler on. Reckoned the job would cost a fiver at best.
    Then I went to Audi and paid £77 for the kit.
    In hindsight, should have toured the scrappies !!!
  6. Re: Snapped Window Cables
    Aug 2007
    i was gonna look in scrappies. but then it it worth the head work. as fault with mine was the wire had frayied and was making a really bugging sound, so if it happened to mine then y not a 2nd hand one. it comes with both runners and mech that motor bolts too. so not a bad price. could of had cables made for a fiver, but only takes em to be a little long or short.
  7. Re: Snapped Window Cables
    Sep 2007
    Glasgow
    Window fixed tonight.
    Straightforward enough if a bit fiddly and frustrating at times - loads of torx bolts of different sizes, big screws, little screws, clips, couple of broken clips.
    Might have cost £77+VAT, but its saved me goodness what in labour !!!
    Haynes manual came in quite useful.
  8. Re: Snapped Window Cables
    Oct 2005
    Labour saving is the biggest thing.
    VW wanted around £200 to investigate and then attempt a repair, add on parts, and so on and your smile becomes even bigger.
    Good work
  9. Re: Snapped Window Cables
    Sep 2007
    Glasgow
    Took me about 30 mins to get the trim off and 30 mins to get the frame out. Then an hour and a half to get it all back together again. Most of the time is taken up by looking, marking, noting, aligning and fiddling with things like the &$%£*$ bolt that goes in the side of the door above the lock.
    2.5 hrs for a dumpty like me, call it 1.5hrs for a VAG tech, so that'll be another £200 +VAT to fix on top of the £200 to investigate (assume the worst) plus parts.
    Oooooouch.
  10. Re: Snapped Window Cables
    A buddy of mine has a similar issue (not checked exactly what the problem is, but pretty sure its the same as this thread).
    I take it there are no issues with resetting ECU / Alarm etc?
    E
  1. VAG COM Which Cables?
    By flex786 in forum VCDS - General Questions
    Last Post: 19-08-2008, 07:42 PM
  2. 409 compatible cables
    By kurtas2006 in forum VCDS - General Questions
    Last Post: 23-05-2008, 04:45 PM
  3. Where to get AMI cables - especially USB ones
    By AndyH123 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 31-03-2008, 10:08 PM
  4. ebay VAG cables
    By pazur in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 05-09-2007, 10:55 PM
  5. Elec Window Cable snapped
    By Timbo in forum Archive posts
    Last Post: 20-07-2007, 10:14 PM
