Thread: Audi S4 Engine cut out
  1. Audi S4 Engine cut out
    My S4 cut out on me on Saturday morning, all the ignition lights are still active and no warning light came on prior to the engine cutting out, the recovery guy stuck his head underneath the fuel tank and said he couldnt hear the fuel pump running when i cranked it over, the same thing happened a few weeks back but after about 10 mins the car started again and was fine, this time however i had to be towed home and have still not been able to start the car. anyone had a similar problem or have any ideas? fuel pump relay i'm guessing would b the place to start but no have idea which one it is??
  2. Re: Audi S4 Engine cut out
    bumping this thread... still not been able to start the car, a friend tried plugging in his solus machine but it would not communicate with the ECU, we also found the fuel pump relay was not powering up whilst cranking, manually toogled the relay and it got the fuel pump working but still no start. ive checked it out on a battery and the relay itself seems fine.... immobiliser fault? cant really think of anything obvious
  3. Re: Audi S4 Engine cut out
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    If machine wont communicate with the ECU then i would be looking at the supply fuse to the ECU.It did sound like a relay fault but the fact you dont get a code or a warning lamp sounds like it has no power.If it was an Immob.fault the engine would start and cut-out after about a second,every time.
  1. Audi a6 tdi AFN engine
    By radupinti in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 22-04-2008, 04:24 PM
  2. KTM X-Bow with Audi FSI engine
    By onzarob in forum Chat - Anything with wheels
    Last Post: 24-07-2007, 03:35 PM
  3. Audi A4 1.9 tdi engine oil
    By junior in forum Audi A4 - Archive Topics
    Last Post: 27-05-2007, 05:46 PM
  4. Audi A4 1.8T engine
    By grsait in forum Chat - Completely Off Topic
    Last Post: 10-05-2006, 08:25 PM
